For your info if your air-cond suddently become warm and hot
1.You should check your air-cond system (Gas level) but nt top up
2.If gas leak (Where and Why) - Air-cond gas will remain up to 10 years , gas won't be dissappear itself
3.If you only top up gas and let it run but never really check the leaking spot ,it will cause compressor oil level go low and will cause compressor jam (Damage)
4.Air-cond Theory same as Engine Theory , if ur engine is leaking , oil level become low and low, imagine what will happen to ur engine and piston when oil left 2L or 2 1/2L ???
5.If your'r in low budjet to repair ur air-cond system , you can only refill the gas n kip running but request the mechanic to refill
compressor oil too.
6.But it won't last long cause gt leaking spot !!
7.You can find some used part example , Compressor , cooling coil
8.If cooling coil (under you dashboard) leaking , air-cond gas won't have big effect to ADULTS but to babys or child may cause BIG PROBLEM (asma) because air-cond contain chlorofluorocarbons (a harmful gas to human body)
I'm a mechanic and i hereby sharing some air-cond knowledge to every1 here, i believe every 1 have their own reliable mechanic or workshop.
---------- Post added at 01:53 PM ---------- 6 hour anti-bump limit - Previous post was at 01:52 PM ----------
Yup, some compressor alone already RM1500 to 2000.....
Bro , wat model of car u driving??
