BT 6Speed Gear Issue.
LuXun
152
Ipoh, JB
Hi all sifu,
I've my ae101 convert to bt 6spd for 5 years. Recently i've having issue to shift from 5 gear to 4 gear.
A "grrrrrk " sound heard, it is like clutch not fully pressed. I've chg new clutch, but problem still there.
Any idea?
kennix
203
5
3,018
Have you tried with different GB oil?
I have the same problem. GB oil I've tried - Q8, Toyota, Redline.
Q8 - will have this problem cold start. After some running, it is better but still with the "grrrrk" sound.
Toyota - Same as Q8
Redline - No such issue but after 30k KM run, this will happen...
Anyway, just to share... hope it helps...
LuXun
152
Ipoh, JB
Toyota - Same as Q8
thx for the info. Currently i'm using mogul gb oil for lsd for 2years already. Maybe i'll try chg to
Other brand oil.
romen_
188
49
kl
The sound means that your synchros are gone.. just open it up and replace them :)
Wolfrayet
Jun 10, 2011
11
i too just got a 6speed levin.. any ideas what would be better as a gear box oil ? yr motul is mineral / semi or syn ? how often do change yr gearbox oil ? anyone can advice ??
tappetoes
74
1,508
Klang,Shah Alam
try redline blue gel...b4 using this g/oil..my gearbox also sound 'grrrkk' when shiftin'..but after using this oil until now (1year)..dont hav any sound grrrkk when shifting n smooth..
i suggest this gear oil if dont have a budget..coz motul,torco and other performance brand is quite expens..
kennix
203
5
3,018
Yeah, I'm using what Tappetoes suggested. Used to be on the yellow bottle one...can't remember the model...
If not mistaken, around RM6x or RM7x per bottle. You need 3...
Correct me if I'm wrong...
Wolfrayet
Jun 10, 2011
11
hi luxun,
yr motul gb oil..is it mineral or semi or syn ? and how often u change the oil ?
as far as i know motul is the best but i understand now its repacked in vietnam ??
torco which one..? i am think of syn. gear oil, any recommendations ?
---------- Post added at 11:46 AM ---------- 6 hour anti-bump limit - Previous post was at 11:41 AM ----------
redline is it this one
Lightweight ShockProof ??
LuXun
152
Ipoh, JB
hi luxun,
Hi Wolfrayet,
Motul gb oil i used is syn, i chg only when i hv problem to shift gear.
so far after 2years never chg before.
It still give me smooth gear shifting, i think mty problem lies to only 4 gears.
From 5 to 4 gear, 3 to 4 gear no issue.
wan to pasang lowering spring for my car...got bad effect o not? does the improvement in handling comes at the cost of comfort?
