anti thief security system
tkew
99
4
1,508
why u need one as your car already have the built in immobiliser.
Stock standard immobilisers imho are useless. It basically means it has design specs and can be reversed engineered like what happened with Myvi's.
Go get yourself an aftermarket alarm with a wireless immobiliser (Clifford), GPS tracking and install a hoodlock too. Always throw in an extra backup battery option in case they somehow manage to get past the hoodlock and disable your battery.
Tilt sensor, shock / microwave sensor, 2-way alarm remotes, wireless immobiliser, steering column pedal lock, 6mil security tint, GPS tracker alarm and if you're extreme enough, get the accessory shop to custom add a taser to the door handles. :biggrin: (show cars have successfully done this btw and it's not legal.)
D7zul
2,697
848
Shah Alam
Polis & JPJ won't know that.. unless they try to steal ur car
:biggrin:
bera
822
229
i like the taser idea... :idea: very james bond-ish...
ed78
353
29
question: any of you guys know how your alarm sounds like? just thought of it........... looks like i have to try and steal my own car now just to find out how the alarm sounds like...........
Uh.. your alarm control should be able to activate the alarm manually. No need so drastic break into own car just to hear what it sounds like!
Speaking of which there was youtube vid I saw where this bloke changed his siren to a lady having a really violent orgasm and it blasted really loud inside and outside the car. Kinda cool idea to have that cuz that'll attract attention for sure! :biggrin: Not like those wussy "bee boo bee boo" alarms that we hear daily and almost everytime ignore....
wongjjeric
Aug 17, 2011
27
503
Better ask Your (trusted) accesories shop to install a ( hiding switches) to cut fuel pump or the ignition .
Make sure the wiring is hiding and better to install along the original wiring (hide) ....to prvent the theft found it.
That s wat i do and teached by my good friend which work in accesories shop....( normally the shop worker simply installed the switches and do the normal wiring cause save time and easy work.)
ed78
353
29
bro,
i don't have a panic button om my remote :confused: do you?
Unite
31
sp
Hi Wong;
can you tell me which accesories shop u did it?cost how much?
Once you lock the car, try pressing the lock button again. Usually that activates the alarm. My Clifford does that
wongjjeric
Aug 17, 2011
27
503
Hi Wong;
oh....bro...the accesories shop belong s to my buddy...but situated in JB...
I think normal installation cost will be not more than Rm 100...but u must have a trusted installer to do so...
Tell him u need to cut the fuel pump by install a hidding switches or u can use some original button which is no function one...
Tell him not to get the wire from dash board instead looking the wire from behind pump or under the seat.....( anywhere )
Make sure he use the black colour wire and hide together in the original wire hardness.....
( i think there is the best way and cheap way to prevent your car from theft.)
For my coming car....I will install switches to cut fuel pump and modified some wire to do so...
For sure my buddy won t charge any money for that....:rolleyes:
Unite
31
sp
Is good.But careful on ur car sensor and make sure ur fren got the circuit diagram.My fren only bypass his car LCD screen and may be tat wireman touch the car sensor,and cause his car check engine sign will appear on and off.
yesterday my car was broken into....
lost apexi safc2 D1 Imamura gold edition which was hidden, RSM 1st gen. Apexi mechanical vacuum meter.
anyone seen selling this items pls do pm me..thanks
