Well,if only with spirited drive i believe alfa got the edge to be faster and easier to drive considering that torqey 2.0 twinspark engine..but in fullspeed uphill i'm afraid conti engine got high risk of overheating..furthermore IF that alfa was auto...in this case neo got the upperhand where campro being rev happy and nimble..could be a tight battle..still alfa would be easier to drive fast..the rest wether win or not all depends alot on outside variable factor..my best opinion is u need to test drive both and chose what u like
Nah won't overheat la..not a last century car dude! The ones that you see tersadai contis are typically older contis or with poor maintenance. If you replace the wear and tear items like lthe water pump, thermostat every 120k kms per recommendation which isn't too expensive. Most owners target their 3rd timing belt change to replace apprx every 120k. The alfas with the temperatures fluctuating are ones with a dying thermostat. Otherwise will be rock steady 80-90 range. the auto you refer to in Selespeed system is called city mode...it's a clutch based system much like the savvy amt in case you didn't know. In city mode it hold revs a lot harder based on throttle response. Driven in manual it's a joy. There is no auto torque converter based alfa with exception of the 156 2.5 v6 and the 164/168. Flick it to manual by engaging a lower or higher gear can be done manually pushing the lever and it's like a regular manual with super fast gear shift done by a robot. The gti runs on similar system but it's a faster dual clutch system.
