Radiator Repair
YEN96
232
JB/SGP
anyone try repair radiator before ...maybe got smal leak ?? Can it be repaired and last ??? How much and How they repair ?? Is it patch the leak ?? cos i recondition radiator for bike before, the person will change the centre fin structure to modify for better cooling using copper fins...and join to the main original frame structure. But it expensive !!!
Any cheap repair and can last ?????
AD_EG
6,328
231
Ipoh
y not just change bro? to double layer or after market double layer aluminium
xtremeleo
3,247
464
5,183
yes, u can repair a car's radiator sir, from experience the process wasnt dat expensive
DanzEterna
15,911
3,371
www.primeperdanaclub.com
if minor leak could be repaired, get a quotation 1st. compared it with new double layer alluminium ones.
---------- Post added at 10:40 AM ---------- 6 hour anti-bump limit - Previous post was at 10:40 AM ----------
otherwise, halfcut ones should be your choice.
YEN96
232
JB/SGP
how they repair ??? weld back the leak ?? i m talking abt aluminium radiator and coolant need to flush and change or no need ?? New aluminium ones cost RM200-300 i tink so i jus want to know if minor leak how much is repair cost ?
YEN96
232
JB/SGP
how much for minor leak repair ??? Does coolant need to flush ??? and how much cost for new aluninium radiator ???
YEN96
232
JB/SGP
i repaired include labour and use back old coolant RM110 but even after they check pressure test after repair, still minor leak !..............
xtremeleo
3,247
464
5,183
u need to get it fixed by a good radiator repair shop sir, ive done this many times, and the results were very good and last long
YEN96
232
JB/SGP
yup, confirm still minor leak. Looks like their applied some aluminium look solder on the pin hole leaks but my coolant is blue so easily can detect leaks. Going down to ask them to rework it.....
xtremeleo- any advise how is a good workmanship and process to repair aluminium radiator since u got gd results
xtremeleo
3,247
464
5,183
u need to monitor when they do leak/compression test, shudnt leak anything out imo. sum of them dont even bother to check their work, dats the bad one imo
skye_n1
36
2
1,508
My radiator leaks and the foreman quoted me RM320 to repair it. Yea, it's quite expensive since it is made from copper and 6-7 fins were leaking. After some thought i change the complete unit for RM470 :thefinger:
YEN96
232
JB/SGP
bro, how did they repair ur radiator ?? is your aluminium ? got spray new coat of paint after repair?
xtremeleo
3,247
464
5,183
they opened it up, wash thotoughly before re-assembling it. i think upgrading to a thicker radiator shud be good also especially when the repair cost is dat expensive
YEN96
232
JB/SGP
Is yours aluminium ? was it leaking ? how was repair done ? weld or solder ? a new coat of paint sprayed ??
xtremeleo
3,247
464
5,183
they were mostly copper radiators sir, they spray painted the fins black, braze-welded imo. aluminum radiators are harder to service, usually i ask them to flush it with chemical and performed leak test
greetings to all forumers.
i want to get some advice from expert of buying used satria neo.
im planning to buying used satria neo next month:driver:, preferably neo Hline auto 06-09.
firstly, what are the aspect that i should look ? is it the faulty gearbox? unusual fc or engine sound? and what is the command problems can be spot in 06-09 satria neo?
secondly, is it true..the higher the car price, the better the car is? :hmmmm: in case of being cheated by the car seller.. my...
