- Joined
- Oct 17, 2007
- Messages
- 112
- Points
- 1,516
Totall frame and string unity. Maximize speed and power!
The new Yonex MusclePower 45 will replace the Muscle Power 44 and Muscle Power 66. It is even balance racket, a change from the MP-44 and MP-66 that are head light balance. It is also the same length as MP-66 which is 10mm longer than MP-44. The racket should give more power because it is more head heavy. We felt it that way when we were swinging the sample racket from Yonex.
Muscle Power is Yonex's futuristic design of rounding corners to help realize the frame's full power potential. Instead of seating the string on the sharp points of a traditional grommet hole system, Muscle Power seats the string on Round Archways that cause no string stress-load and no fatigue through contact friction. The construction creates total unity of the frame and string because they are in much closer and tighter contact. The face stability that results from rounding the corners lets you smash with a new magnitude of aggression.
"Durability" helps hold tension:
Compared with the Muscle Power construction, a conventional badminton racquet's less durable construction demonstrates a sharp and progressive curve of diminished string tension over time.
String tension remains at its peak:
Seven days after stringing, the stringbed of the Yonex Muscle Power Frame badminton racquets continues to provide constant high resiliency for powerful hits.
Energy transfer is maximized:
No energy is lost. No energy is wasted. Compared with the conventional badminton racquet, the Yonex Muscle Power constructioin keeps the badminton racquet frame and string in closer and tighter contact so that they function as a single unit to transfer the full magnitude of smash energy at impact directly to the shuttlecock. At the split-second of impact, the entire frame "receives" the full magnitude of the hit, instantly snapping the shuttlecock away with explosive power.
New gateway to speed:
Yonex Muscle Power badminton racquet's explosive combination of advanced construction and performance features -- Round Archways - total unity of the frame and string - outstanding face stability and durability - and consistent playability across the entire stringbed -- pack 5% more speed into smash shots. Enough to win the edge over any competition.
Level: Intermediate / Advance
Type: All Around / Offensive
Flex: Medium
Head: Square/Isometric
Weight: 85-89.9gm(3U-)
Balance Point: 6 (Even Balance)
Head: High Modulus Graphite
Shaft: High Modulus Graphite
Cover: Yonex Full Cover
TECHNOLOGY:
MusclePower:
Muscle Power seats the string on rounded archways that eliminate stress load and fatigue through contact friction. The construction creates total unity of the string and frame through closer and tighter contact.
Isometric:
The isometric square head shape equalizes the length of main and cross strings in the stringbed, enlarging the sweetspot for more consistent accuracy even on off-center hits.
Built-In T-Joint:
Moulded deep into the layers of graphite where the frame conects with the shaft, the Yonex built-in T-joint creates a durable and high strength one-piece frame that is torque-free.
SOLD
TQ
Flex: Medium
TECHNOLOGY:
MusclePower:
Isometric:
Built-In T-Joint:
SOLD
TQ
