WTS: Zaptor Monster Series Voltage Stabiliser
kelfo
Bukit Bintang
WTS: Zaptor Fusion Series Voltage Stabiliser
We like to take this opportunity to inform you of our New Addition to our
Zaptor Fusion Series. The 3 New Models for 2011:
a) 50,000uF, b) 100,000uF c) 150,000uF
Fusion Series maybe Small in Size, but Mighty in Performance
Incorporating a New Ultra High Microfarad Design, our Voltage Stabilizers not only Improves, the car Electrical, Electronic Circuitry and also the Mechanical Aspects too.
The New Design has the Ability to Filter a Wider Range of Unregulated A/C Spikes from the Alternator and turn it into a Smooth Constant D/C current supply, which will increase and stabilize the Current Output to the Car Battery and other Electrical Parts, such as the ECU, Sensors, Fuel Pumps, Air-con, Headlights and Lights, etc.
The Current Surge causes your Car Electrical Supply to loose Power Momentary, which affects must modern day cars ECU’s with Electronic & Electrical Sensors. With our High Microfarad Design, it supports High Current Surge, (E.g. When the Air-con Kicks in, the Lights will Dim) by Accumulating a Bigger Electrical Reserve, thus compensating the High Electrical Current Surge.
Our New Models are made from High Quality CNC Alloy Housing, which provides a robust enclosure for the Electronic Components inside. A Safety Fuse is Incorporated to our Design to prevent Electrical Fires incase of Reverse Polarity or an Accident. The Fuse Holder is Built Externally for easy access. Our New LED Indicator, it provides Proper Voltage Indication at a Glance, which ranges from 10V Red, 11V Orange to 12V Green. The 4AWG/ 8AWG Wires are made from Oxygen Free Cables which minimizes Electrical Resistance.
Performance & Fuel Economy is Guaranteed. All our Zaptor Voltage Stabilizers carry a 24mth warranty. Our Nationwide Dealers will be at your Assistance should you need any Advice or Support.
1. All Components Specs are 25V 105 degrees (Not Local Spec 16V 85 Components)
2. Intelligent LED Voltage Indicator (10v, 11v & 12v)
3. Ultra Compact Design (Fits Almost Anywhere)
4. CNC Alloy Housing
5. External Fuse for Easy Fuse Change
6. Light Weight
7. Ultra High Microfarad 50k, 100 & 150k
8. CAD designed Fiberglass Circuit Boards
9. 4 / 8 Gauge Oxygen Free Cables (OFC)
10. Multi-Staged Capacitors Filters
http://zaptor.webs.com/
We wish thank all our Loyal Customers, Friends & Dealers and look forward to your Continuous Support. As promised, we will be launching our New Models very soon!
Thank you all for your Inquiries...
The new 50K model is RM200.00, 100k Model is RM300.00, 150k Model is RM400.00
Now our Promotion Price for all our Zaptor Customers...
RM248.00 for the New "100,700uF Fusion Voltage Stabiliser"
Just Bring along your Old Unit...
Guaranteed will outperform RM600 ones...
Call now at 016-3808883.
Some Recent Customer Feedbacks...
Customer 1...
Hi bro,
Hmmmm, just installed this afternoon with the zaptor fusion.
First impression is that the engine is quieter!
I think the pickup, i.e. acceleration is better.
I think for the money, its a definite recommendation!
All the best in your sales, will keep you updated after further testing.
Customer 2...
installed this afternoon the zaptor fusion.
First impression - TS very nice n frenly (help me install my Fusion + Grouding Kits) under Hot Sun n explain to me wads he is doing for every step
engine more quite ? YES ! normally i force the car to accelerate engine quite loud 1
acceleration smoother ? can feel it right after installing
Anyway i do recommend this seller coz he is super frenly n nice guy
pix for the installation on my car
Customer 3...
hello and good day to all. im one of the first who installs zaptor fusion (im faridzul - 1st one who booked the ZF) haha. and im using 2001 red waja 4g18 mitsubishi engine.
improvement :
- straightaway after install ZF and grounding, my engine is quieter at idle. - 1st improvement
- improve torque and acceleration and probable HP bump. i can feel the newly found torque and acceleration ( my car is nearly 10 years old!) and i need to drive back carefully in the traffic jam to prevent any accident with the new torque ( seriously).
- brighter headlamp and other lamp in the car or outside. (10-15% brighter)
- smoother power delivery from engine\
- less kick from aircond (not noticable now)
- more clear sound from the radio~
- faster aircond cool time. really fast compared to before.
