- Joined
- Jun 30, 2008
- Messages
- 1,493
- Points
- 1,648
Works Engineering Power-Plus Throttle Body increase horsepower and orque by optimizing airflow to your engine. On forced induction applications, this quick bolt-on has sown gains of 50-Hp. On high-output naturally aspirated engines, we have seen gains of 10+Hp. Our larger bore throttle bodies are capable of flowing enough air to support over 500hp.
Work Power-Plus Throttle Bodies are precision CNC-Machined from forged AL6061-T6 billet aluminium, vacuum tested, and hard anodized for increase durability.
Application List:
Honda B16,20, H22, B18C and D series - 70mm
Subaru Ver.7 / 8 Sti - 70mm
Mitsubishi EVO 1-3 / 4G93 / 4G93T / 4G92 / Mivec - 70mm
Mitsubishi EVO 4-8 - 70mm
Nissan Silvia S14/15 - 70mm
Rm650.00-900.00
*Price might change without notification, kindly contact me to confirm the price. TQ
*Please Inquiry / Order by E-mail
Website: www.xd-auto.com
Contact No.: KentGoh - Digi 6 - 337 3368
E-Mail: [email protected]
Shop Location: Kepong Jaya Jusco
Installation & Tuning: Kepong Jaya Jusco
Business Hour: 10.00am - 7.00pm (Monday - Saturday)
Lunch Time: 1.00pm - 2.00pm
Delivery Service: 11.00am - 6.00pm (Monday - Saturday)
Our shop:
Win Hong Auto Trading Sdn Bhd
No.153, Jalan Besar Kepong, 52100 K.L
Maps: http://wikimapia.org/#lat=3.2139519&lon=101.6382739&z=18&l=0&m=m&search=win hong auto
Dear All Members and Forumers,
I would appreciate if you guys kindly DO NOT PM/Call to me especially on XD-Autoparts related Products, Quotation, Technical Issues and etc.
I'm more than glad to answer you guys if you guys inquiry by E-mail to [email protected] or SMS to Digi 6 - 337 3368. This is to ensure better tracking and a more efficient follow up.
Thank you for understanding, cheers.
Regards,
KentGoh
Engine Performance & Compartment
ASR Silicone Hose - http://www.zerotohundred.com/newfor...s-asr-silicone-hose-products.html#post4121197
Auto Service & Replacement Parts - http://www.zerotohundred.com/newfor...cement-and-performance-parts.html#post3858120
Bardahl Lubricants - http://www.zerotohundred.com/newforums/engine-and-performance/341331-wts-bardahl-fully-5w30-and-5w40-rm85.html
Bosch Fusion Spark Plugs - http://www.zerotohundred.com/newfor...ance/237425-wts-bosch-fusion-spark-plugs.html
Bosch Type-R Oil Filter - http://www.zerotohundred.com/newfor...mance/244853-wts-bosch-type-r-oil-filter.html
Chemlube Lubricants - http://www.zerotohundred.com/newfor...chemlube-100-syncthetic-with-ester-based.html
Cold Air Intake Hose - http://www.zerotohundred.com/newforums/engine-and-performance/234747-wts-cold-air-intake-hose.html
Exedy Clutch - http://www.zerotohundred.com/newfor...ce/341326-wts-exedy-clutch-and-fly-wheel.html
Forged Racing Radiator - http://www.zerotohundred.com/newforums/engine-and-performance/362689-wts-forged-racing-radiator.html
Pivot Products - http://www.zerotohundred.com/newfor...223310-wts-genuine-pivot-raizin-products.html
Haydens ATF Cooler - http://www.zerotohundred.com/newfor...-hayden-transaver-all-weather-protection.html
Denso Iridium Spark Plugs - http://www.zerotohundred.com/newfor...nce/303916-wts-denso-iridium-spark-plugs.html
K&N High Flow Filter - http://www.zerotohundred.com/newfor...-n-high-flow-drop-in-and-open-pod-filter.html
Motul Lubricants - http://www.zerotohundred.com/newfor...ance/223342-wts-motul-lubricant-products.html
Pennzoil Lubricants - http://www.zerotohundred.com/newfor...ance/341332-wts-pennzoil-platinum-series.html
Q8 Lubricants - http://www.zerotohundred.com/newforums/engine-and-performance/341333-wts-q8-lubricants-products.html
Redline LCP - http://www.zerotohundred.com/newforums/engine-and-performance/322721-wts-redline-lightening-crank-pulley.html
Hot InaZma Products - http://www.zerotohundred.com/newfor...-products-hot-inazma-hot-earth-hg-pocket.html
Torco Lubricants - http://www.zerotohundred.com/newfor...41337-wts-torco-sr-1-and-sr-5-lubricants.html
Works Air Intake System - http://www.zerotohundred.com/newfor...-wts-works-engineering-air-intake-system.html
Works Cam & Crank Pulley - http://www.zerotohundred.com/newfor...s-works-engineering-cam-and-crank-pulley.html
Works Drop In Filter - http://www.zerotohundred.com/newfor...724-wts-works-engineering-drop-in-filter.html
Works Fuel System - http://www.zerotohundred.com/newfor...341343-wts-works-engineering-fuel-system.html
Works Magnetic Oil Sump Nut - http://www.zerotohundred.com/newfor...-works-engineering-magnetic-oil-sump-nut.html
Works Oil Cooler - http://www.zerotohundred.com/newfor...ering-oil-cooler-engine-and-transmission.html
Works Oil Filter Relocator - http://www.zerotohundred.com/newfor...s-works-engineering-oil-filter-relocator.html
Works Racing Power Steering Tank - http://www.zerotohundred.com/newforums/engine-and-performance/341350-wts-works-engineering-racing-power-steering-tank.html
Works Throttle Body - http://www.zerotohundred.com/newfor...rks-engineering-power-plus-throttle-body.html
Works Sensor Adapter - http://www.zerotohundred.com/newfor...-wts-works-engineering-sensor-attachment.html
Works Silicone Hose Kits - http://www.zerotohundred.com/newfor...wts-works-engineering-silicone-hose-kits.html
Works Thermal Wrap - http://www.zerotohundred.com/newfor...41355-wts-works-engineering-thermal-wrap.html
Chassis & Handling
APM Performax Suspension Products - http://www.zerotohundred.com/newfor...6-wts-apm-performax-products.html#post3053352
Bendix Metal King Brake Pads - http://www.zerotohundred.com/newfor...ts-bendix-metal-king-titanium-brake-pads.html
Brembo Standard Disc Rotor - http://www.zerotohundred.com/newforums/chassis-and-wheels/341309-wts-brembo-standard-disc-rotor.html
EBC Brake Pads - http://www.zerotohundred.com/newforums/chassis-and-wheels/362688-wts-ebc-brake-pads-made-in-uk.html
Eibach Pro-Kits Spring - http://www.zerotohundred.com/newforums/chassis-and-wheels/242432-wts-eibach-products.html
GAB Suspension - http://www.zerotohundred.com/newforums/chassis-and-wheels/352610-wts-gab-suspension-products.html
Pro RS Steel Brake Hose - http://www.zerotohundred.com/newfor...42876-wts-prors-steel-braided-brake-hose.html
Tanabe Suspension - http://www.zerotohundred.com/newforums/chassis-and-wheels/359603-wts-tanabe-suspension-products.html
TEIN S-Tech Spring - http://www.zerotohundred.com/newforums/chassis-and-wheels/311108-wts-tein-s-tech-lowered-spring.html
TEIN Basic Damper - http://www.zerotohundred.com/newforums/chassis-and-wheels/289072-wts-tein-basic-damper-offer.html
TEIN Super Street - http://www.zerotohundred.com/newforums/chassis-and-wheels/289071-wts-tein-super-street-offer.html
Ultra Racing Bars - http://www.zerotohundred.com/newfor...-wts-genuine-ultra-racing-stabilizer-bar.html
Exterior & Body
Bosch Aerotwin Wiperblades - http://www.zerotohundred.com/newforums/exterior-and-body/228047-wts-bosch-aero-twin-wiperblades.html
Dyno Silicone Wiperblades - http://www.zerotohundred.com/newforums/exterior-and-body/303917-wts-dyno-silicone-wiperblades.html
Goodyears Graphite Wiperblades - http://www.zerotohundred.com/newfor...ts-goodyears-silentarmor-graphite-wipers.html
Philips Light Bulb - http://www.zerotohundred.com/newforums/exterior-and-body/229529-wts-philips-lighting-products.html
Tanabe Number Plate Holder - http://www.zerotohundred.com/newforums/exterior-and-body/238776-wts-tanabe-number-plate-holder.html
Interior & Cockpit
Works Gear Knob - http://www.zerotohundred.com/newfor...6-wts-works-engineering-teflon-gear-knob.html
