- Joined
- Jun 30, 2008
- Messages
- 1,493
- Points
- 1,648
Works Engineering universal adjustable fuel pressure regulator can be remotely mounted on ANY application thats utilizes a return hose. This unit is capable of supporting enough fuel flow for engines in excess of 1000 horsepower, and is ideal for forced-induction engines since it is boost dependent (1:1 ratio).
- CNC-machined from 6061-T6 billet aluminium
- Interchangeable discharge ports match regulator output to output of any fuel pump
- Adjustable from 20 psi to maximum fuel pump capacity
- Maintains stable fuel pressure at high-horsepower levels
- Sensitive adjustment allows setting of optimum fuel pressure
- Service hole in regulator prefect for pressure gauge installation or as a feed for nitrous system or additional injector setup
- Mounting bracket included
W-FPR-I - Works Fuel Regulator Stage-1 (up to 600bhp)
W-FRP-II - Works Fuel Regulator Stage-2 (up to 1200bhp)
Works Engineering Fuel Pressure Regulator With Meter
Stage 1 - Rm320.00
Stage 2 - Rm400.00
Works Engineering Fuel Pressure Regulator Bracket are dedicated adaptors for installation adjustable fuel pressure regulator, it mounts directly onto factory fuel rail. The adaptor are car specific and machined from aluminium with blue anodized aluminium finish.
W-FRB-H - Fuel Regulator Bracket Set for Honda Civic
W-FRB-E4 - Fuel Regulator Bracket Set for Evo 4 above, Toyota, Nissan
W-FRB-E3 - Fuel Regulator Bracket Set for Evo 1-3, Proton
Rm40.00
Larger injector upgrades may not work with many factory fuel rails, therefore we offer upgrade performance fuel delivery rail kits. Upgrading to a performance fuel delivery pipe expands injector sizing options for your vehicle as well as reliable fuel delivery. Works Engineering Fuel Rail Kits are high-performance fuel delivery units that are designed to preperly supply the additional fuel needed for high boost/performance applications.
All fuel rails are CNC billet aluminium, large non-restrictive bore maintains maximum pressure and fuel volume at each injector decreasing the chance of fuel cavitations. They are direct bolt-on replacements of factory fuel rails for specific vehicle applications and allow for larger top-feed injector to be added. Kit comes with all necessary fittings, block off plates and grommets for ease of installation.
Note: Intended for Racing of Fast Street usage only. To be installed by trained professional only. Please ensure all fittings are properly secured and tested.
Application List:
Mitsubishi 4B11 EVO 10
Mitsubishi 4G63 EVO 4 / 5 / 6 / 7 / 8
Mitsubishi 4G63 EVO 1-3 & VR4
Mitsubishi 4G93
Proton Campro Series
Honda B Series DOHC
Honda K Series DOHC
Honda D Series DOHC
Subaru GDB (2pcs)
Suzuki Swift 1.5 / 1.6, Solio 1.3
Toyota Supra 3.0 2JZ
Rm330.00-600.00
In racing condition, high lateral G force can cause the fuel "slosh" around the fuel tank, which can lead to a loss of fuel pressure from the fuel pump and hence causing the engine to run lean and damage it. The fuel surge tank can eliminate this effect, and also offer the option of running two fuel pumps to ensure there is always constant supply of fuel under all conditions.
Works Engineering fuel surge tank is specially designed for street performance which allows you have to increase fuel pump flow capacity and will reduce lean run conditions while doing high lateral G. Our fuel surge tank hold 2 liters of extra fuel and TIG welded 6061 aluminum.
- CNC-machined from 6061-T6 billet aluminum
- Machine Welding
- 2 Liter capacity
Works Engineering Aluminum Fuel Surge Tank
Rm850.00
*Price might change without notification, kindly contact me to confirm the price. TQ
*Please Inquiry / Order by E-mail
Website: www.xd-auto.com
Contact No.: KentGoh - Digi 6 - 337 3368
E-Mail: [email protected]
Shop Location: Kepong Jaya Jusco
Installation & Tuning: Kepong Jaya Jusco
Business Hour: 10.00am - 7.00pm (Monday - Saturday)
Lunch Time: 1.00pm - 2.00pm
Delivery Service: 11.00am - 6.00pm (Monday - Saturday)
Our shop:
Win Hong Auto Trading Sdn Bhd
No.153, Jalan Besar Kepong, 52100 K.L
Maps: http://wikimapia.org/#lat=3.2139519&lon=101.6382739&z=18&l=0&m=m&search=win hong auto
Dear All Members and Forumers,
I would appreciate if you guys kindly DO NOT PM/Call to me especially on XD-Autoparts related Products, Quotation, Technical Issues and etc.
I'm more than glad to answer you guys if you guys inquiry by E-mail to [email protected] or SMS to Digi 6 - 337 3368. This is to ensure better tracking and a more efficient follow up.
Thank you for understanding, cheers.
Regards,
KentGoh
Engine Performance & Compartment
ASR Silicone Hose - http://www.zerotohundred.com/newfor...s-asr-silicone-hose-products.html#post4121197
Auto Service & Replacement Parts - http://www.zerotohundred.com/newfor...cement-and-performance-parts.html#post3858120
Bardahl Lubricants - http://www.zerotohundred.com/newforums/engine-and-performance/341331-wts-bardahl-fully-5w30-and-5w40-rm85.html
Bosch Fusion Spark Plugs - http://www.zerotohundred.com/newfor...ance/237425-wts-bosch-fusion-spark-plugs.html
Bosch Type-R Oil Filter - http://www.zerotohundred.com/newfor...mance/244853-wts-bosch-type-r-oil-filter.html
Chemlube Lubricants - http://www.zerotohundred.com/newfor...chemlube-100-syncthetic-with-ester-based.html
Cold Air Intake Hose - http://www.zerotohundred.com/newforums/engine-and-performance/234747-wts-cold-air-intake-hose.html
Exedy Clutch - http://www.zerotohundred.com/newfor...ce/341326-wts-exedy-clutch-and-fly-wheel.html
Forged Racing Radiator - http://www.zerotohundred.com/newforums/engine-and-performance/362689-wts-forged-racing-radiator.html
Pivot Products - http://www.zerotohundred.com/newfor...223310-wts-genuine-pivot-raizin-products.html
Haydens ATF Cooler - http://www.zerotohundred.com/newfor...-hayden-transaver-all-weather-protection.html
Denso Iridium Spark Plugs - http://www.zerotohundred.com/newfor...nce/303916-wts-denso-iridium-spark-plugs.html
K&N High Flow Filter - http://www.zerotohundred.com/newfor...-n-high-flow-drop-in-and-open-pod-filter.html
Motul Lubricants - http://www.zerotohundred.com/newfor...ance/223342-wts-motul-lubricant-products.html
Pennzoil Lubricants - http://www.zerotohundred.com/newfor...ance/341332-wts-pennzoil-platinum-series.html
Q8 Lubricants - http://www.zerotohundred.com/newforums/engine-and-performance/341333-wts-q8-lubricants-products.html
Redline LCP - http://www.zerotohundred.com/newforums/engine-and-performance/322721-wts-redline-lightening-crank-pulley.html
Hot InaZma Products - http://www.zerotohundred.com/newfor...-products-hot-inazma-hot-earth-hg-pocket.html
Torco Lubricants - http://www.zerotohundred.com/newfor...41337-wts-torco-sr-1-and-sr-5-lubricants.html
Works Air Intake System - http://www.zerotohundred.com/newfor...-wts-works-engineering-air-intake-system.html
Works Cam & Crank Pulley - http://www.zerotohundred.com/newfor...s-works-engineering-cam-and-crank-pulley.html
Works Drop In Filter - http://www.zerotohundred.com/newfor...724-wts-works-engineering-drop-in-filter.html
Works Fuel System - http://www.zerotohundred.com/newfor...341343-wts-works-engineering-fuel-system.html
Works Magnetic Oil Sump Nut - http://www.zerotohundred.com/newfor...-works-engineering-magnetic-oil-sump-nut.html
Works Oil Cooler - http://www.zerotohundred.com/newfor...ering-oil-cooler-engine-and-transmission.html
Works Oil Filter Relocator - http://www.zerotohundred.com/newfor...s-works-engineering-oil-filter-relocator.html
Works Racing Power Steering Tank - http://www.zerotohundred.com/newforums/engine-and-performance/341350-wts-works-engineering-racing-power-steering-tank.html
Works Throttle Body - http://www.zerotohundred.com/newfor...rks-engineering-power-plus-throttle-body.html
Works Sensor Adapter - http://www.zerotohundred.com/newfor...-wts-works-engineering-sensor-attachment.html
Works Silicone Hose Kits - http://www.zerotohundred.com/newfor...wts-works-engineering-silicone-hose-kits.html
Works Thermal Wrap - http://www.zerotohundred.com/newfor...41355-wts-works-engineering-thermal-wrap.html
Chassis & Handling
APM Performax Suspension Products - http://www.zerotohundred.com/newfor...6-wts-apm-performax-products.html#post3053352
Bendix Metal King Brake Pads - http://www.zerotohundred.com/newfor...ts-bendix-metal-king-titanium-brake-pads.html
Brembo Standard Disc Rotor - http://www.zerotohundred.com/newforums/chassis-and-wheels/341309-wts-brembo-standard-disc-rotor.html
EBC Brake Pads - http://www.zerotohundred.com/newforums/chassis-and-wheels/362688-wts-ebc-brake-pads-made-in-uk.html
Eibach Pro-Kits Spring - http://www.zerotohundred.com/newforums/chassis-and-wheels/242432-wts-eibach-products.html
GAB Suspension - http://www.zerotohundred.com/newforums/chassis-and-wheels/352610-wts-gab-suspension-products.html
Pro RS Steel Brake Hose - http://www.zerotohundred.com/newfor...42876-wts-prors-steel-braided-brake-hose.html
Tanabe Suspension - http://www.zerotohundred.com/newforums/chassis-and-wheels/359603-wts-tanabe-suspension-products.html
TEIN S-Tech Spring - http://www.zerotohundred.com/newforums/chassis-and-wheels/311108-wts-tein-s-tech-lowered-spring.html
TEIN Basic Damper - http://www.zerotohundred.com/newforums/chassis-and-wheels/289072-wts-tein-basic-damper-offer.html
TEIN Super Street - http://www.zerotohundred.com/newforums/chassis-and-wheels/289071-wts-tein-super-street-offer.html
Ultra Racing Bars - http://www.zerotohundred.com/newfor...-wts-genuine-ultra-racing-stabilizer-bar.html
Exterior & Body
Bosch Aerotwin Wiperblades - http://www.zerotohundred.com/newforums/exterior-and-body/228047-wts-bosch-aero-twin-wiperblades.html
Dyno Silicone Wiperblades - http://www.zerotohundred.com/newforums/exterior-and-body/303917-wts-dyno-silicone-wiperblades.html
Goodyears Graphite Wiperblades - http://www.zerotohundred.com/newfor...ts-goodyears-silentarmor-graphite-wipers.html
Philips Light Bulb - http://www.zerotohundred.com/newforums/exterior-and-body/229529-wts-philips-lighting-products.html
Tanabe Number Plate Holder - http://www.zerotohundred.com/newforums/exterior-and-body/238776-wts-tanabe-number-plate-holder.html
Interior & Cockpit
Works Gear Knob - http://www.zerotohundred.com/newfor...6-wts-works-engineering-teflon-gear-knob.html
Thx you
i m looking for ganador side mirror for SW20,who got lubang to get it XD,come hlp me,replica 1 oso no problem
