(WTS) Torco & Liqui Moly Engine Oil
kennywee
:top:
Item(s): Engine Oil
Price: PM if interested
Dealing method: Currently COD only
Location of seller: Kuchai Lama
Contact method/details: 018-2170799 (whatsapp/sms/call) or PM
Age of item: NEW
Picture:
Torco TR-5 SAE 10W40 Synthetic Blend Engine Oil
Torco TR-5 Synthetic Blend Motor Oils are blend of hydro processed petroleum base stocks, special polymers and proprietary additive systems
focused on superior performance and engine protection. TR-5 is tried and proven race formula that offers excellent thermal stability under extreme
RPM and high operating temperature of modern racing engines. TR-5 protects against scuffing, galling and metal transfer for longer engine life.
Torco Synthetic Motor Oil SR-1 (Available in 5w30, 5w40, 10w30 and 10w40)
SR-1 is a selective cross blend of highly advanced 100% synthetic base oils and proprietary additives aimed at power efficiency and engine
protection.
SR-1's performance is not compromised by
standardized additive technology or by our competitors' price points, it is simply a purpose built, specialty formula designed to exceed the demands
of high performance Japanese, European and US sports cars.
A combination of Generation-2 MPZ and low friction base oils reduce frictional losses to increase horsepower and torque by as much as 3%. A
premium polymer and additive system controls viscosity for long term durability, maximum engine protection and eliminate engine deposits.
Torco SR-1 is the ultimate in high performance synthetic motor oil technology. No other synthetic motor oil meets the performance and protection
benefits of SR-1.
Features & Benefits
- 100% Synthetic Formula
- Generation-2 MPZ frictional loss technology
- Increases horsepower & torque
- Reduces operating temperatures
- Advanced engine protection
MoS2 Leichtlauf 10 W-30 and 10 W-40
The MoS2 anti-friction lubricant forms a high load-bearing film of lubricant on all friction and sliding surfaces. The MoS2-lubricant film reduces the
resistance to friction and allows engines to run -- so they conserve more energy even under extreme conditions. MoS2 Energy Conserving
guarantees: significantly less fuel and oil consumption. Significant wear reduction, fewer breakdowns and emergency lubrication properties. Stable
to ageing and stable viscosity. Good cold-start behaviour and high operational reliability. Prevents sludge formation. Tested on catalytic converters
and turbochargers.
Leichtlauf Special AA 5 W-30
Modern premium class low-friction motor oil that was specially developed for year-round use in Japanese and American vehicles. The combination of
unconventional base oils using synthetic technology together with the latest additive technology guarantees a motor oil that provides exceptional
protection against wear, reduces oil and fuel consumption and keeps the engine clean while ensuring fast oil penetration of the engine. Oil change
intervals of up to 8,000 km are thus possible, depending on the manufacturer’s specifications.
Top Tec 4100 5 W-40 (Available in 4L and 5L)
Top Tec 4200 5 W-30 (Available in 5L only)
Is a top quality, state-of-the-art low-friction motor oil for use all year round. Guarantees a motor oil that provides exceptional protection against wear
and reduces oil and fuel consumption, while ensuring that the engine is immediately supplied with oil. In addition, Top Tec 4100 is best suitable for gas
fuelled (CNG/LPG) passenger cars.
Synthoil Race Tech GT1 10 W-60
Energy-conserving for extreme conditions. With the wide-range viscosity 10 W-60 HD. High thermal stability. Lubrication is also reliably maintained at
extreme temperatures. Optimises engine performance. Immediate lubrication during cold starting and significantly improved wear protection. Fine-
tuned to the demands of the latest generation power units (multi-valve and turbocharged).
Cera Tec
CERA TEC is a high-tech ceramic wear protection product for all motor oils. CERA TEC reduces friction and wear due to ceramic compounds that withstand
extremely high chemical and thermal loads. Prevents direct metal-to-metal contact, thus increasing the engine service life. The low-friction effect
reduces fuel consumption in gasoline and diesel engines. Sufficient for 5 liters of motor oil.
PS : LiquiMoly Engine Flush 300ML available now!
Reason for sale: Helping all forum people to get cheaper price! :rock:
Can leave post or contact me by PM/SMS/Call/Whatsapp for other Engine Oil & Car parts too for low price! :top: Contact no : 018-2170799
PS : I do have feedback from buyer from LYN. Feel free to ask me if you have any enquiries! :biggrin:
