[WTS] Skil 6513 set Percussion Drill Set
All Other Stuff
maswaretools
http://www.maswaretools.com/media/catalog/product/cache/1/image/9df78eab33525d08d6e5fb8d27136e95/s/k/skil_6513_set_percussion_drill_set.jpg
Applications:
This powerful impact drill is suitable for Professionals, Do-It-Yourself projects, Home maintenance, Garage work, Office maintenance, Technicians & Tradesman.
Skil 550w impact drill is Multi function impact hammering action makes it suitable for drilling in wall, concrete, wood, metal & Plastic. Forward / Reverse Switch & Variable Speed Switch functions makes it suitable for screw driving & removing old screws, for making bigger holes / cutouts using optional hole saw cutters
Features:
- Ergonomic design and optimal grip area for comfortable gripping
- Reliable motor of 550W with strong ball and needle bearing system
- Easy to control with the “fit-for-two-fingers” variable speed trigger
- Forward/reverse
- Lock-on button for continuous application
- Large knob for easy switching between impact and drilling mode
Specifications (Skil 6513 Impact Drill)
- Input power: 550W
- Chuck type: 13mm (keyed)
- No load speed: 0-3,000 rpm
- Impact rate: 48,000 bpm
- Drilling diameter: 13mm(steel), 16mm(masonry), 35mm(wood)
- Variable switch: Yes
- Forward/reverse: Yes
- Auxiliary handle: Yes
- Depth gauge: Yes
- Net weight: 1.8 kg
Standard Accessories:
138pcs home tool kit - provides holistic solution for all purpose tooling for home use , drilling and screw driving application
- Auxiliary handle
- Depth stop
- Keyed chuck (1.5 to 13mm)
- Plastic carry case
- Flat Wood Boring Bit 16-20 = 2pc
- 50 mm Bits CR-V = 10pc
- Bit Holder = 1pc
- Wood Drill: 5-6-8 = 3pc
- Masonry Drill: 5-6-8 = 3pc
- Metal Drill” 6-6-8 = 3pc
- 6" Linesman Pliers = 1pc
- 8 oz Claw Hammer = 1pc
- Utility Knife =1pc
- Screwdrivers = 2pc
- Screws and Plugs =111pcs
- Total weight: 4.8 kg
- Price : RM188.00
Maswaretools Online Store
The online hardware shop
Visit our website for more tools & equipments available online!
Any inquiry please e-mail to [email protected]
Come and contact us for all your hardware tools and machinery needs.....
Any inquiry please e-mail to [email protected] or you may contact us directly to Mr. Yim @ 03-42912336 / 03-42913887
-BUMP-
Supplier of high tech machineries, tools and equipment | Masware Enterprise (KL) Sdn Bhd
-BUMP-
New Posts
