- Joined
- Mar 20, 2006
- Messages
- 510
- Points
- 1,518
SCANGAUGE II - 3 in 1 Automotive Computer
http://i120.photobucket.com/albums/o185/nicholas1007/18052008508.jpghttp://i120.photobucket.com/albums/o185/nicholas1007/18052008518.jpg
http://i120.photobucket.com/albums/o185/nicholas1007/18052008525.jpghttp://i120.photobucket.com/albums/o185/nicholas1007/18052008531.jpg
- 3 in 1 Automotive Computer (Trip Computer / Digital Gauges / Scan Tools)
- Easy to connect = just connect to the OBDII / EOBD port, turn on the ignition key & SCANGAUGE II will automatically connects to your cars internal computer.
- Size Length 4.8†x Height 1.5†x Thickness 1â€
- Suitable for most OBDII & EOBD compliant vehicles
- 7 standard screen colors & custom setting of 63 possible colors.
- Stored information inside SCANGAUGE II is not lost when disconnected.
- Easily move from vehicle to vehicle
- Showing real time display information bout your vehicle.
- (NEW) New Horsepower Reading available in newly purchased SCANGAUGE II
- (NEW) Transmission Temp, Cylinder Head Temp, AFR Reading ……………can be read for selected vehicle.
FUNCTION:
Trip Computer: Automatically stores data for 4 trips, stores TODAY & PREVIOUS DAY data. Provide information bout fuel used, to empty & distance (Fuel information can be calculated after a simple setting by user). The TRIP mode can be used to save petrol, improved driving habit can improve fuel economy.
- Maximum Speed
- Average Speed
- Maximum Coolant Temp
- Maximum RPM
- Driving Time
- Driving Distance
- Fuel Used
- Trip Fuel Economy
- Distance To Empty
- Time To Empty
- Fuel To Empty
Digital Gauges: SCANGAUGE II can display up to 4 of 12 possible gauges at the same time. The unit of measure can be changed & the rate of update can be increase & decrease.
- Fuel Economy (Litre/KM)
- Fuel Rate
- Battery Volt
- Coolant Temp
- Intake Air Temp
- RPM
- Vehicle Speed (MPH / KMH)
- Manifold Pressure
- Engine Load
- Throttle Position
- Ignition Timing
- Open/Close Loop
Scan Tools: Check for Diagnostic Trouble Codes. If any of codes found, can display how many codes there are & the Trouble Codes themselves. Can be used to clear the Trouble Codes & will turn off the CHECK ENGINE light.
- Reads Trouble Codes
- Reads Condition that set the Trouble Code
- Clear Trouble Codes
- Turn off ‘CHECK ENGINE’ Light
- Tells you when vehicle is ‘Ready’ to pass OBDII Testing
- Make & Store up to 10 rewritable special codes to send to the vehicle computer
Price : RM700.00 (Last Set)
CONTACT: 012-4747155
*Call For Viewing.*
FUNCTION:
- Maximum Speed
- Average Speed
- Maximum RPM
- Driving Time
- Driving Distance
- Fuel Used
- Trip Fuel Economy
- Distance To Empty
- Time To Empty
- Fuel To Empty
- Fuel Rate
- Battery Volt
- Coolant Temp
- Intake Air Temp
- RPM
- Manifold Pressure
- Engine Load
- Throttle Position
- Ignition Timing
- Open/Close Loop
*Call For Viewing.*
