DELL D280P POWER SUPPLY
Technical Details
Dell F5114 280 Watt Power Supply for Optiplex GX280 Small Desktop, L280P-00, X9072, Liteon PS-5281-3DF, D280P-00, NC912, M8803, Delta DPS-280DB A
Note! It may be necessary to purchase an IDE to Sata adapter if your existing power supply has sata connectors.
DELL N305P POWER SUPPLY
Technical Details
Optiplex: 740, 745, 755
305 Watt Power Supply
Dell Model Number: NPS-305HB A
Dell Part Number: JH994 (or a compatible part number)
DELL L375P POWER SUPPLY
Technical Details
This power supply is a compatible replacement for part numbers:
KH624, PH344
Also a compatible replacement with model numbers:
L375P-00, N375P-00
Compatible Systems:
Dell Dimension 9100, 9150, 9200
Dell XPS 400, 410, 420
Dell Precision WorkStation 380, 390, T3400
DELL L220P POWER SUPPLY
Technical Details
Dell Power Supply 220W DP/N: 0K8965 K8965 Model: L220P-00 for Dell OptiPlex Desktop Computer GX280, GX520 and GX620.
DELL N275P POWER SUPPLY
Technical Details
For Dimension 5100C and Optiplex GX620 SFF
Identical Dell part # K8964 TD570 YD080 N8373
DELL TFX0250D5W POWER SUPPLY
Technical Details
Dell TFX0250D5W Replacement Power Supply 250w Part Number XW605
This is a Dell replacement power supply model number TFX0250D5W and part number XW605 (OXW605) SFFCN-0YX301, CN-0XW605. Dell Inspiron 530S, 531S.
DELL N230N POWER SUPPLY
Technical Details
DELL 0PC357 N230N-00 230 Watt Power Supply
FOR DELL DIMENSION 3100/E310
DELL DPS300AB POWER SUPPLY
Technical Details
Dell Inspiron and Vostro Mini Tower Power Supply, 300W, DPS-300AB-24, Dell XW601
SKU: 7565
Dell 300W Power Supply for Select Inspiron and Vostro Mini Tower, DPS-300AB-24, Dell XW601.
compatible Dell Models:
Dell Vostro: 200 and 400 Mini Towers
Dell Inspiron: 530 and 531 Mini Towers
Item: Dell Power Supply Unit
Conditions: Working Unit
Status: Refurbish / used unit
Warranty: 30days
Contact email/msn: [email protected]
Tel: 012-3573035 call/sms
Contact: michael (mike3666)
Picture: -nill- but can use google to search the above models
Price: RM80++
if intrested please provide your damage power supply unit model number to recomfirm your actual PSU that you need to replace.
Technical Details
Technical Details
Technical Details
KH624, PH344
L375P-00, N375P-00
Compatible Systems:
Technical Details
Technical Details
Technical Details
Technical Details
Technical Details
SKU: 7565
Warranty: 30days
Price: RM80++
