[WTS] Brake and Clutch Locking Device For Car (Brand New)
xing55
PRO.A.T-LOCK (Brand New)
For wira manual only
-High security car lock
-easy installation
-easy to use
RM230
Interested can PM me, call or sms me - 0168715005 (David)
PM me best price bro..
COD loc..?
SET for Auto n Manual. Thanks
Bro, this item can adjust for different clutch position? Because some proton clutch further to left and some further cause have leg rest. Mount to steering shaft? Made locally?
Lastly, your location and best price plz, tq:adore:
PRO.A.T-LOCK
What does it do?
It instantly locks your vehicle's brake pedal and clutch pedal with one lever pulley. Fully customize to fit your car's pedal spacing.
Where is it located?
It's placed under your steering's neck, right below the wirings. It is locked onto the steering wheel's neck (only if the neck is reachable, if not it will be locked onto other permanent holders).
How does it work?
Basically it holds onto the brake pedal and clutch pedal when you pull the lever. It's hassle free. No more adjusting steering lock here and there. You can now securely lock your car with one pull. The ignition key lock is located under the steering wheel. Easily accessible when unlocking it.
What is it made of?
View to appreciate. It's made from heavy hard densed steel in which makes it virtually impossible to cut it.
BUMP BUMP BUMP...
Then if lets say after installing this lock i decided to add leg rest which requires the clutch pedal to move right a bit, by then, can the lock stil be adjusted? Thx bro:adore:
