[WTS] Baofeng and Motocopa Walkie Talkies
All Other Stuff
BlueMagic
Hi all,
I have 3 units of 2 Way Radios for sale. 1 Pair of Motocopa and 1 Unit of Baofeng. Below are the features of the respective units. Thanks.
BAOFENG UV-5RE
The transceiver is a micro-miniature multiband
FM transceiver with extensive receive frequency coverage,
providing local-area two-way amateur communications along with unmatched monitoring capability
VHF/ UHF DUAL-BAND TWO WAY RADIO
Frequency Range: 136-174 / 400-480MHz
Dual-Band Display, Dual Freq. Display, Dual-Standby
Output Power: 4 /1Watts
128 Channels
50 CTCSS and 104 CDCSS
Built-in VOX Function
1750Hz Brust Tone
FM Radio (65.0MHz-108.0MHz)
LED Flashlight
Large LCD Display
Hight /Low RF Power Switchable
25KHz/12.5KHz Switchable
Emergency Alert
Low Battery Alert
Battery Saver
Time-out Timer
Keypad Lock
Monitor Channel
Channel Step: 2.5/5/6.25/10/12.5/25KHz
ROGER SET
MOTOCOPA
-Frequency Range 134-176mhz and 400-520mhz(widest range)
Key Feature:
Package come with dualband telescopic Antenna
-FM radio mode
-Torch Light function
-Alarm Alert
-128 Momery Channels
-7W Transmitting Power for VHF,Long Distance Communication
-DTMF-ANI
-Remotely Stun/Remotely kill
-Scrambler(NEW FUNCTION)
-Channel Capacity 99
-Channel Spacing 5/6.25/10/12.5/20/25KHz
-Operated Voltage 7.4V
-Battery Capacity Hi cap-1900MAh Li-ion
-Dual Band /Dual Watch
-Dual Display
-Priority Channel Scanning
-VOX Function
-Crossover band
-Emergency Alarm
-1750Hz Tone
-High Illumination Flashlight(LED torch light)
