- Joined
- Oct 15, 2007
- Messages
- 56
- Points
- 1,506
ITEM ONE: High performance 4 channel power amplifier (AQ-A1004PS)
FULL MOSFET POWER SUPPLY
VARIABLE FREQUENCY 10HZ-30KHZ
S/N RATIO > 95db
SUB WOOFER FREQUENCY CONTROL
POWER BANDWIDTH 18KHZ-22KHZ
TRI-GANGE PROTECTION CIRCUIT
1 OHM STABLE
CIRCUIT OVERLOAD PROTECTION
4 x 100 WATTS RMS
Price: RM 980.00
http://i202.photobucket.com/albums/aa223/ninicoco20/Amplifier/AQA1004PS.jpg
ITEM TWO: High performance 2 channel power amplifier (AQ-A2002PS)
S/N RATIO > 95db
1 OHM STABLE
2 x 200 WATTS RMS
Price: RM 980.00
http://i202.photobucket.com/albums/aa223/ninicoco20/Amplifier/AQA2002PS.jpg
ITEM THREE: High performance CLASS D MONO amplifier (AQ-A2500PS)
CLASS D MOSFET POWER SUPPLY
VARIABLE LOW PASS 50HZ-250HZ
S/N RATIO > 98db
1 OHM STABLE
1 x 2000 WATTS RMS
Price: RM 1980.00
http://i202.photobucket.com/albums/aa223/ninicoco20/Amplifier/AQA2500PS.jpg
ITEM FOUR: High performance 2 channel power amplifier (AQ-P1702TX)
FREQUENCY RESPONSE 10-30KHZ
S/N RATIO > 90db
FULL SELECTABLE CROSSOVER
T.H.D 0.001%
full selectable crossover
high / low / flat
bass boost
x-over
4 gauge power/ground connections
Fuse protections
hi-end terminal (power/speaker)
Price: RM 698.00
http://i202.photobucket.com/albums/aa223/ninicoco20/Amplifier/AQP1702TX.jpg
ITEM FIVE: High performance CLASS D MONO amplifier (AQ-P3800TX)
S/N RATIO > 90db
2 OHM LOAD CIRCUIT
high / low / flat
bass boost
x-over
fuse protections
Price: RM 688.00
http://i202.photobucket.com/albums/aa223/ninicoco20/Amplifier/AQP3800TX.jpg
ITEM SIX: High performance 2 channel power amplifier (AQ-P5002TX)
S/N RATIO > 90db
T.H.D 0.001%
high / low / flat
bass boost
x-over
fuse protections
Price: 398.00
http://i202.photobucket.com/albums/aa223/ninicoco20/Amplifier/AQP5002TX.jpg
ITEM SEVEN: High performance CLASS D MONO amplifier (AQ-P6000TX)
S/N RATIO > 90db
2 OHM LOAD CIRCUIT
high / low / flat
bass boost
x-over
fuse protections
Price: RM 1188.00
http://i202.photobucket.com/albums/aa223/ninicoco20/Amplifier/AQP6000TX.jpg
ITEM EIGHT: High performance 2 channel power amplifier (AQ-P7502TX)
S/N RATIO > 90db
T.H.D 0.001%
high / low / flat
bass boost
x-over
fuse protections
Price: RM 498.00
http://i202.photobucket.com/albums/aa223/ninicoco20/Amplifier/AQP7502TX.jpg
ITEM NINE: High performance 4 channel power amplifier AQ-7504TX)
S/N RATIO > 90db
T.H.D 0.001%
high / low / flat
bass boost
x-over
fuse protections
Price: RM 598.00
http://i202.photobucket.com/albums/aa223/ninicoco20/Amplifier/AQP7504TX.jpg
SUPER HEAVY DUTY WOOFER (AB-1060)
60OZ MAGNET
2 INCH K.S.V.4 LAYER VOICE COIL
750WATTS RMS PEAK POWER
49.90 LITERS OF VAS..
SENSITIVITY 86+-3db
4 OHM
FREQUENCY RESPONSE 30HZ-3KHZ
Price: RM 660.00
http://i202.photobucket.com/albums/aa223/ninicoco20/Sound%20system/ab1060.jpg
http://i202.photobucket.com/albums/aa223/ninicoco20/Sound%20system/ab6010-1.jpg
SUPER HEAVY DUTY WOOFER (AB-1280)
60OZ MAGNET
1000WATTS RMS PEAK POWER
SENSITIVITY 86+-3db
4 OHM
Price: RM 740.00
http://i202.photobucket.com/albums/aa223/ninicoco20/Sound%20system/ab1280.jpg
http://i202.photobucket.com/albums/aa223/ninicoco20/Sound%20system/ab1280-1.jpg
65MM HI-TEMP ASV VOICE COIL (AQ-P12TX)
50 OZ MAGNET WEIGHT
40HZ-3500HZ FREQUANCY
1000WATTS MAX POWER LOAD
Price: RM 770.00
http://i202.photobucket.com/albums/aa223/ninicoco20/Sound%20system/aqp12tx.jpg
50MM HI-TEMP ASV VOICE COIL (AQ-P120TX)
50 OZ MAGNET WEIGHT
800WATTS MAX POWER LOAD
Price: RM 590.00
http://i202.photobucket.com/albums/aa223/ninicoco20/Sound%20system/aqp120tx.jpg
50MM HI-TEMP ASV VOICE COIL (AQ-P1250TX)
50 OZ MAGNET WEIGHT
Price: RM 390.00
http://i202.photobucket.com/albums/aa223/ninicoco20/Sound%20system/aqp1250tx.jpg
PM or SMS us to 012-7515 653 or 012-903 8807 or 012-308 6011
V Zone Motorsport
S/N RATIO > 95db
1 OHM STABLE
4 x 100 WATTS RMS
Price: RM 980.00
S/N RATIO > 95db
1 OHM STABLE
2 x 200 WATTS RMS
Price: RM 980.00
S/N RATIO > 98db
1 OHM STABLE
1 x 2000 WATTS RMS
Price: RM 1980.00
S/N RATIO > 90db
T.H.D 0.001%
high / low / flat
bass boost
x-over
Fuse protections
Price: RM 698.00
S/N RATIO > 90db
2 OHM LOAD CIRCUIT
high / low / flat
bass boost
x-over
fuse protections
Price: RM 688.00
S/N RATIO > 90db
T.H.D 0.001%
high / low / flat
bass boost
x-over
fuse protections
Price: 398.00
S/N RATIO > 90db
2 OHM LOAD CIRCUIT
high / low / flat
bass boost
x-over
fuse protections
Price: RM 1188.00
S/N RATIO > 90db
T.H.D 0.001%
high / low / flat
bass boost
x-over
fuse protections
Price: RM 498.00
S/N RATIO > 90db
T.H.D 0.001%
high / low / flat
bass boost
x-over
fuse protections
Price: RM 598.00
60OZ MAGNET
SENSITIVITY 86+-3db
4 OHM
Price: RM 660.00
60OZ MAGNET
SENSITIVITY 86+-3db
4 OHM
Price: RM 740.00
50 OZ MAGNET WEIGHT
Price: RM 770.00
50 OZ MAGNET WEIGHT
Price: RM 590.00
50 OZ MAGNET WEIGHT
Price: RM 390.00
V Zone Motorsport
