(EA) Works Engineering ATF & Engine Oil Cooler Kit
IMPORTANT REMINDER: Read this post thoroughly before you ask. When you are calling/SMS, kindly introduce yourself (name, forum, car model).
http://www.autoworks.com.my/images/logo%20animated.gif
WORKS ENGINEERING ATF COOLER KIT
Prolong your autotransmission lifespan by removing accessive heat generated under hard driving. The bar-and-plate cooler design increases oil capacity, higher flow and minimum lost of pressure.
http://a5.sphotos.ak.fbcdn.net/hphotos-ak-ash2/36141_156556974366879_100000377312513_344537_4604273_n.jpg
WORKS ENGINEERING ENGINE OIL COOLER KIT
Prolong your engine lifespan by removing accessive heat generated under hard driving. The bar-and-plate cooler design increases oil capacity, higher flow and minimum lost of pressure. Stainless steel braided hose and bendo-joint ensure safe application and durability. Double O-ring on the filter adapter prevents leakage, thus more reliable.
http://a3.sphotos.ak.fbcdn.net/hphotos-ak-snc3/11440_101601906529053_100000377312513_39806_6283154_n.jpg
WORKS ENGINEERING OIL FILTER RELOCATION KIT
Moves your engine oil filter to a more convenient location. For certain engines, a relocation is required to facilitate the installation of engine oil cooler kit.
http://a1.sphotos.ak.fbcdn.net/hphotos-ak-ash2/36141_156556984366878_100000377312513_344540_8234047_n.jpg
PRODUCT RANGE: Universal for most engine
INSTALLATION: Provided
WARRANTY: 1 Year
CALL: 019-359 3909 (Drex)
Click here for Google Map
WARRANTY: 1 Year
:hmmmm:
