works adjustable volt stabilizer must see
yung
the is the latest technology volt stabelize
because this is suitable for all car wit adjustment
other volt stabilizer dint have adjustment so some car it not function wit the volt stabilizer
this works engineering is adjustable is it will suitable for all car
today modern cars run a lot of electronic device and equipment include air-conditioner,audio,system,speaker,amp,player,lighting,HID,signal,tail lamp,brake light,wiper,alarm,sensor,injector,ignition,spark plug,plug cable,and many other,all these constantly saps power and consume alot of energy,putting alot of strain on battery and alternator ,A 12v-13.8v current may cause problem to the car ignition system including incomplete combustion and carbon build of .in the long term this reduce compression ratio,less bhp,slower accelelation and increase fuel combustion
works pro energizer offer robust,maintenance free protection for electrical load to prevent erratic operation or equiment damange caused sags and surges
feature
-no modification -no maintenance -immediately effect -plug and play -easy setting -fully adjustable upto(15V) -professional equipment
benefit
~improves ignition ,fuel burn ,fuel efficiency
~increase engine torque across the full rev range better throttle respond
~lightens load electrical charging system hence increases lifespan of battery and alternator
~lower exhaust emission with cleaner fuel combustion
dun waste money on the rm1XX pivot and many other volt stabilizer ady
this is your best choice this just exp little bit but u can fell the effect
1 year warranty
sevice manual are include
guaranty money back
if dint have any effect
---------- Post added at 05:14 PM ---------- 6 hour anti-bump limit - Previous post was at 02:44 PM ----------
ump..
