VW Golf
My car is back in Tj Malim to repair the steering rack and replace the oil seals.
Meantime, here are some recent addition to the car :
Neuspeed short shifter :
http://upload4.postimage.org/726658_8e66d84bddb65f981facecfaafb5d150/Neuspeed01.jpg
So did the strut bars!
http://upload4.postimage.org/726683_8e66d84bddb65f981facecfaafb5d150/OMP_strutbars01.jpg
The shift rod ballast is being installed in Tj Malim. Man, this piece of welded metal costs USD35!
http://upload4.postimage.org/726685_8e66d84bddb65f981facecfaafb5d150/Shift_rod_ballast01.jpg
What all VW Enthusiast should know...
CIS and CIS-E Diagnostics
CIS-E Jetronic & Motronic table located below!
CIS TROUBLESHOOTING
SYMPTON Probable
Cause CORRECTIVE
ACTION
1. Cold start-Engine starts hard or fails to start. a.Cold start valve or thermo-time switch faulty
bFuel pump not running
c,Air flow sensor plate position incorrect
d.Fuel pump pressure incorrect a. Test cold start valve and thermo-time switch
b.Check fuel pump fuse & relay
c. Inspect/adjust
d.Test system and cold-control pressures
2.Hot start-Engine starts hard or fails to start a. Hot start pulse relay faulty
b.Cold start valve leaking or operating continually
c.Fuel pressure incorrect
d.Air low sensor plate rest position incorrect
a. Test/replace hot start pulse relay
b. Test valve and thermo-time switch
c. Test warm control pressure
d. Inspect/adjust
e.Insufficient residual fuel pressure
f.Fuel leak(s) e.Test residual pressure.Check fuel pump check valve and accumulator.
f. Inspect all lines and fittings.
3.Engine misses and hesitates under load a. Fuel injector(s) clogged
b.Fuel pressure incorrect
c.Fuel leak(s) a. Test injectors $ lines. Clean/replace.
b.Test system pressure and warm control pressure. Replace pressure regulator if faulty
c.Inspect all lines and fittings.
4. Engine starts but stalls at idle a.Incorrect fuel pressure
c.Auxiliary air regulator faulty
d.Vacumn leak a.Test system/control pressures
b. Test/replace
c.Test/replace
d. Check for leaking hoses, cracks in air intake components,leaking valve cover.
5. Engine idles too fast a. Accelerator cable,pedal,Tbody binding
b. Auxiliary air valve faulty
c.Air leaking past Tbody a.Inspect for worn or broken parts.
b.Test/replace
c.Inspect/adjust/replace Tbody
6. Hesitation during acceleration a.Vacumn leak
b. Fuel injector(s) clogged
c.Cold start valve leaking
d. Control plunger binding or fuel distributor faulty a. See 4d
b. See 3a
c,See 4b
d. Check sensor plate movement/clean control pluger/replace fuel distributor
e. Airflow sensor plate misaligned
f. Fuel pressure incorrect
g.Idle mixture(%CO2)incorrect e.Inspect/adjust
f.Check system/control pressure. Replace control pressur regulator
g. Check/adjust
7. Poor fuel economy a.Idle speed/timing/%CO out of adjustment
c.Fuel pressure incorrect a. Check/adjust
b.Test/replace
c.See 6f
8.Engine runs after shutoff (diesels) a. Incorrect timing or faulty ignitiion
bEngine overheated a. Adjust timing/See IGNITION section
b. Check cooling system
CIS-E and CIS-E MOTRONIC TROUBLESHOOTING
SYMPTOM PROBABLE
CAUSE CORRECTIVE
ACTION
1. Cold Start-Engine fails to start or starts hard. a Cold start valve or thermo-time switch faulty
B.Fuel pump not running
c. Airflow sensor plate rest position wrong Test cold start valve and thermo-time switch.
b.Check fuse and relay.
c. Inspect/adjust
d. Fuel pressure incorrect
e. Coolant temp sensor faulty or wire broken
f. Poor ignition system ground d.Check for leaks. Check differential press. regulator, system and control pressure.
e. Test coolant temp. sensor. Test wiring for continuity.
f. SEE ignition
2.Hot Start-Engine starts hard or fails to start a. Cold start valve leaking or operating continuously.
b. Fuel pressure incorrect.
c. Insufficient residual fuel pressure.
d. Oxygen sensor system faulty a. Test cold start valve and thermo-time switch.
b. See 1d
c. Test/replace accumulator and fuel pump check valve.
See EXHAUST/EMISSIONS
e. Air flow sensor plate position incorrect.
f. Fuel injector(s) faulty.
g. Inadequate fuel delivery
h. Evaporative emission control system faulty on Motronic system. e. Inspect and adjust.
f. Test/clean/replace.
g.Test/replace pump.
h. Check both evaporative control valves/replace.
3. Engine stalls or idles rough a. Fuel pressure incorrect
b. Cold start valve faulty.
c. Fuel injector(s) faulty.
d. Coolant temperature sensor faulty or wiring to sensor broken.
e.Vacumn(intake air) leak. a.See 1d
b.Test/replace valve.
c.Test/clean/replace.
d. Test sensor resistance. test continuity of wiring to sensor.
e.Check valve cover, hoses, plenum, etc.
f. Control plunger binding or fuel distributor faulty.
g.Auxiliary air regulator faulty.
h. Idle air stabilizer valve not operating.
i. Airflow sensor plate position wrong.
j. Incorrect enrichment. f. Test/clean control plunger. replace fuel distributor as necessary.
g. Test/replace.
h. Check wiring/idle switch. Clean ISV.
i. Inspect and adjust.
j. Check wiring/control current to DPR.
4. Engine misses or hesitates under load. a. Fuel injector(s) clogged.
c. Oxygen sensor system faulty.
d. Fuel leaks.
e. Coolant temperature sensor faulty or wiring to sensor broken. a. Clean/test/replace.
b. See 1d
c. See EXHAUST/EMISSIONS
d. Inspect lines/fittings. Correct leaks.
e. See 3d
5. Engine idles too fast a. Accel. cable, pedal, throttle valve binding.
b. Auxiliary air valve faulty.
c. Idle boost valve(s) faulty.
d. Idle air stabilizer valve faulty.
e. Air bypassing throttle body.
f. Evap. emission control faulty (Motronic) a. Check/repair/replace components.
b. Test/replace.
c. Test/replace.
d. See 3h
e. Check hoses/fittings/tbody.
f. Check both control valves/hoses.
6. Hesitation on acceleration a. Vacumn (intake air) leak
b. Fuel injector(s) clogged.
c. Cold start valve leaking.
d. Control plunger binding/fuel distr. faulty.
e. Airflow sensor plate misadjusted.
f. Fuel pressure incorrect.
g.Airflow sensor potentiometer faulty
h. Inadequate fuel enrichment a. See 3e
b. Clean/test/replace.
c.Test/replace.
d. See 3f
e. Inspect/adjust
f. See 1d.
g. Test/adjust/repace.
h. Check wiring/control current to DPR
7. Low power a. Coolant temperature sensor faulty or wiring broken.
c. Throttle plate not opening fully. a. Test coolant sensor resistance values. Check for broken wiring to sensor.
b. Check differential and system pressures. Check DPR.
c. Check adjustment of throttle cable.
d. Full throttle switch faulty or incorrectly adjusted.
e. Airflow sensor screen damaged, clogged, or incorrectly installed.
f. Air filter clogged. d. Check and adjust position of full throttle switch. Replace if faulty.
e. Check installation. Clean/replace screen as necessary.
f. Replace.
8. Poor fuel economy a. Idle speed,timing,CO mixture incorrect.
b. Cold start valve leaking.
c. Fuel pressure incorrect. a. Check/adjust all.
b.Test/replace.
c. See 7b.
9. Engine continues to run after shutoff (diesels) a. Incorrect timing/faulty ignition.
c. Leaking fuel injector(s)
d. Airflow plate/plunger misadjusted.
e.Evaporative control valve faulty.
f. Engine overheated.
a. See IGNITION
b. Test/replace
c. Clean/test/replace.
d. Inspect/adjust.
e. Check/replace vavle.
f. See COOLING SYSTEM
Technical Information
Wolfsburg, 31 July 2006 - The Eos is the top-seller on the convertible market. With 1,559 new vehicle registrations in June, the Eos became the top-selling vehicle of its class in Germany. Almost one in ten new convertibles sold in the month of June was an Eos. This statistic, supplied by the Federal Bureau of Motor Vehicles and Drivers, is particularly remarkable as the basic version of the Eos was not available in June. Delivery of the Eos 1.6 FSI with 85 kW / 115 PS to Europe is now starting (starting price: 25,950 euros).
The Eos range includes two petrol engines (110 kW, 147 kW) and a turbo diesel (103 kW) with a particulate filter fitted as standard. A V6 petrol engine with 184 kW is to be added to the range. Just a few weeks after the European debut of the Eos, trends are starting to establish themselves as to which specifications are preferred by customers: as regards engines, 47 percent of Eos drivers have selected the dynamic 2.0 TFSI with 147 kW / 200 PS, 25 percent have favoured the 110 kW / 150 PS 2.0 FSI, and 24 percent ordered the torquey TDI (103 kW / 140 PS) engine.
Clear preferences can also be seen with colour choices: 37 percent of Eos owners have opted to be seen in "Silver Essence metallic" in the hot European Summer. "Deep Black pearl effect" (27 percent) and "Midnight Blue metallic" (11 percent) are the 2nd and 3rd most popular colour options. 80 percent of Eos owners ordered a fully-automatic "Climatronic" air conditioning system even though the Eos is fitted with the "Climatic" semi-automatic air conditioning system as standard.
The exceptional sales figures are matched by an exceptionally good price: the 2.0 FSI with 150 PS can be purchased for just 245 euros* per month on the "FairEos" payment plan – including comprehensive vehicle insurance for one year, credit security and extended warranty period. Anyone placing an order today can look forward to spending the hot summer, and hopefully, a golden October, an a chic convertible.
Kookaburra .... any more new mods. By the way every thought of a group buy. It may turn out to be cheaper. Do let me know if you intend to get new things ok...
and to all our Muslin brethern "Selamat Berpuasa"
No new mod.....the front strut bar couldn't fit, may need to relocate the coolant reserve tank first. Now i am just enjoying the car first......the shift rod ballast is a beauty, I love changing gears :D
im selling off my vw golf MK1 Gti ( 4 Doors )
its a 1.6 gti automatic transmition
full original BBS bodykit from germany
15''sports rims
mk2 dashboard
original steering
refurnished interior
overhaul engine
selling at RM 15k. nego.
anything u can just PM me..
the car is around KL
dder bmw,
wanna sell the bbs kit or swap with a zender kit (original) ?
eoj
osF,
hahahahaa..... spot on !!!! BBS mah.
H2o,
not sure actually. probabaly just the side skirt's lenght.
DDer bmw,
how bro ?
eoj
0193214937
hello golfers....
behalf of my fren he wanna sell 40dcnf webber with tapak mark 1..including k&n filters...
asking for rm 400 nego...if interested can pm me..
tq.
haha
guys, he want to sell the car. not the bodykit.
the bodykit come together with the car.
i guess if u want it u have to buy the car.
the year of the car im not so sure.
but i can check.
dder bmw,
ahh.... i tot its yr car. i think i know of this car. the fella at man-donna's place told me about this car with the BBS kit.
by the way, there is no such thing as an auto or 4 door MK1 GTi. your friend's car is probabaly a GLi.
if the car is still not sold and if he wants a "new look"....would your friend wanna trade with a zender ? i'll check with u again later.... thks !!!!
eoj
