GRB Spec C is looking for a new enthusiast owner.
- Very rare (in Malaysia,900 worldwide). Future classic/collectors' item.
- Very careful owner, and only the best/original parts used
- Timely serviced (every 5k km), with original parts and quality oil
- Stock Standard
- No Modification
- Full Service History(all receipts to proof)
Vehicle Details :
* Year of manufacture : 2009
* Registration date : 2011
* Mileage : 69,000 km
* Exterior Colour : BLUE
* Interior : SUBARU RECARO SEMI LEATHER
* Engine cubic capacity : 1994cc
* Manual Transmission - 6 Speed
serious buyer only..low ballers won't be entertained..
- RM195,000
- Price is negotiable
- Loan can be arranged.
- Call for viewing pleasure!
- Car driven once a week and sometimes 1 times a month on weekend
- Reason for selling? No reason..Just looking at the possibility.If price offered doesn't match my expectations
I'm happy to keep the car
- 012-7433911 - Hjjemee
Fuji Heavy Industries Ltd. (FHI), the maker of Subaru vehicles, has officially unveiled the Subaru Impreza WRX STI spec C in Japan which is already available through Subarudealerships. Only 900 units will be produced.
The 2009 Subaru Impreza WRX STI spec C / GRB is a hardcore version of any Impreza model featuring enhanced engine and chassis performance as well as lighter body.
The STI spec C comes with reprogrammed ECU, turbocharger with new ball bearings for the turbine axle bearing, specially designed front and rear suspension system, improved body rigidity and chassis.
The Impreza STI spec C is lighter thanks to the aluminum engine hood, laminar window glasses and a downsized battery.
Below are the official details of the Subaru Impreza WRX STI spec C from the press release.
Enhancement of Engine performance:
Ball bearings of the turbine axle were newly adopted to reduce friction in the turbocharger. With the optimized ECU programming, the engine offers smoother and quicker response to the accelerator pedal and excellent accelerating performance.
An inter-cooler water spray prevents rise in intake-air temperature at continued high-load driving, providing stable engine performance and improved efficiency.
Enhancement of Chassis performance:
Reinforcement of the cross member in front-suspensions offers a linear steering response.
Specification changes in damping force of suspensions, coil spring rate, rear stabilizer and rear sub-frame bushes optimize rigidity for body roll and retain excellent road-holding capability.
Rear LSD (Limited Slip Differential) system was changed to a mechanical type from a Torsen type to obtain the steady and powerful traction during cornering.
Bridgestone “POTENZA RE070″ (245/40R18) were adopted to enhance cornering ability and higher grip performance, especially in dry conditions.
Nimble handling with a firm steering feel is assured by increasing oil flow volume in the power steering system.
Lightened body:
An aluminum engine hood and a downsized battery, which make the front section of the vehicle lighter, produce better maneuverability.
Laminar glasses were adopted in the front and side windows. They lightened the upper section of the body weight, resulting in improved stability during cornering.
Newly-designed lightweight 18-inches alloy wheels are standard to offer excellent road-hugging property by reducing unsprung weight. (17-inches alloy wheels are optional)
A flat tire repair kit is standard, which also helps weight reduction.
Others:
A structural change of fuel pomp provides stable fuel delivery even on high-load driving.
Gold colored “brembo” brake calipers are standard.
The front bucket seats (fabric with red stitch) are standard on models with 18-inches alloy wheels.
The “RECARO” seats (Alcantara and leather combination with red stitch) are optional on models with 18-inches alloy wheels.
Two exclusive exterior colors are available; Sunrise Yellow and Pure White.
The production is limited to 900 units.
Major specifications:
Engine type: Horizontally-Opposed 4-cylinder DOHC 16-valve turbocharged engine
Displacement: 1,994 cc
Maximum output: 227kW (308 PS)/6,400 rpm
Maximum torque: 422 Nm (43.0 kgf.m)/4,400 rpm
Turbo type: Ball-bearing type twin scroll turbocharger
https://www.youtube.com/watch?v=LAE2gY2Dfb0
https://www.youtube.com/watch?v=ZcgWAjW9iNQ
https://www.youtube.com/watch?v=JV8PgWsYnYM
https://www.youtube.com/watch?v=v9-NogSjhyQ
https://www.youtube.com/watch?v=J22cNM7VW4Y
- Stock Standard
- No Modification
Vehicle Details :
- RM195,000
Lightened body:
Others:
