STACK Display Dash ST8102
fastclubman
I have a STACK dash display for sale. Used but in excellent condition. This is a race dash with data logging capability (512KB) and with lap timing and predicitve lap timing function. Dash comes with real carbon fibre surround (originally taken from Mazda Miata Race Car), wiring harness -mil spec, Lateral G sensor, CAN bus cable, 4 switches mounted on a panel. Will display oil pressure, oil temp, fuel pressure, water temp, rpm, speed, voltage and lap timing. Can be fitted to any car.
Can download software to download logged data and analyse sector times, G loading, speed and so on. Good for hardcore track kaki's.
Change of plans, so I am letting this go. Serious buyer only, price can be negotiated slightly.
0123350607
nope temp sensors can use any other and calibrate to suit. Pressure sensors should be 5v output type, then can use. if you previously use Sard Oil Pressure or Fuel Pressure gauge, then u can use the same sensors on the STACK.
