Looking for Old Skool Rare SoundStream amp?
Handcrafted in The USA
INfo :
RMS Power (2 ohms)100 watts x 4 ch, + 400 watts x 1 ch.RMS Power (1 ohm)Not StableMinimum Impedance Unbridged2 ohmsMinimum Impedance Bridged4 ohms (2 ohms for the sub chan in bridged mode)
INfo :
- 5-Channel Van Gogh Series
- RUBI™ (Rapid-Use Branched Impulse) proprietary power supply topology
- STACT™ (STabilized Apex Current Topology) Reduces power supply stress 50%
- Trident™ amplifier protection topology
- Ultra-Low ESR Capactiance Bank ensure rapid power delivery for dynamic peaks
- Hawkins Bass Control™ Proprietary bass equalization topology
- IDI™ (Intelligent Distress Indicator) gives visual indication of amplifier protection status
- Harmonic Bass Alignment™ produces tighter, more accurate bass
- Fully regularted MOSFET power supply
- Triple Darlington Output Circuitry
- BIP™ Bias Input Protection
- Rail Stabilization Protection Circuitry
- Bi-linear selectable two-way crossovers for amplifier and line outputs
- Continuously Variable High and Low Pass Crossovers
- Balanced Line Inputs for the Highest Level of Noise Rejection
- Platinum RCA Inputs and Outputs
- Platinum 2-gauge Power Connectors
- Tri-mode operation
- Damping Factor: > 500
- Input Sensitivity: 0.15-12.0 Volts
- Crossover Frequency: 30Hz - 4kHz (at 12dB)
- Dimensions: 11.2" x 2.6" x 19.7"
