Recommended brake pads,lines & fluid
pengyu
Hi all,
What's the recommended brake pads,lines and fluid for mostly daily driven car and occasional tracks.
And also, where to get them and how much?
thanks =)
Bro,
Brake line: Endless
Brake rotors: Project U (2 piece/floating type)
Brake pads: Project U
Brake fluids: MOTUL RBF660
Cooling panel for the rotor...
Brake pads for the track use (once awhile), you may need the medium/high (500 degree & above) temperature type which is you may need to warming up the pads before the race. But not suitable for daily driven. It will worn out the rotor faster then you expected.
Other reputable brand like Endless & AP Racing rotors more expensive.
thanks bro! where r u now? bila turun KL?
I wont change the rotors yet i think, because its already 2 piece.
Im changing the pads,fluid and lines first and i want to see the improvements.
im searching for good suspension at the moment, but unfortunately i scrap the hell out of my front bumper at my apartment's parking already..so i dont think im able to lower it.
the suspension now is pretty good in terms of grip and comfort..but damn too much body roll for my liking when touge.
I was thinking to change the anti roll bar, but couldnt find anything thicker or stiffer than OEM ones in stock. Hate to order it.
btw, anyone else want to add regarding the brakes? Which shops will you recommend me to go? Buy and install.
I've change mine to ProRS hose, Endless Brake Pads 500 front and 300 rear and Endless brake oil. So far I've no complain, still using the ori Brembo caliper and rotor on my E9.. If your rotor surface is not even, I suggest to do a round of skimming before putting on the new set of brake pads.. :)
bro evoke, may i know how much the cost for the brake pad???rear??is it:hmmmm: still have noisy when braking using endless brake pad?
Around RM300plus for the rear.. So far so good.. don't have any sound :tongue:
Bendix pads Street are good performance for daily use, but it didn't last after 9 continous rounds in Pasir Gudang :driver:
Endless brake oil 5.1 is very good.. I bought 1L for Rm 85.
rotor - project mu 1 piece (msia most shops can source for u)
pads - project mu HC+ (800c) front and rear (japan)
fluid - ate super blue (sg)
hose - goodridge (msia)
that's what i'm on..
aiya pengyu... easy la... come my shop lolx... maybe i give u some poisons... wahahaha
btw when cuming back KL? lolx
