question on B-Series timing belts
moonster98
what's your timing belt change interval? how frequently do you change it & under what driving conditions - normal/hard/heavy traffic/track?
& when you change your timing belt what else do you change with it?
timing belt interval should be 100,000km. change with spark plugs (standard is NGK platinum which is good for 50,000km). tune engine timing. Also good to adjust valve tappets. inspect conditions of alternator and pwr steering belts, change as necessary. flush radiator too. the list goes on. somebody fill up the list.
I change at 60-70K. Wouldn't want it to snap when I'm hitting 8K rpm... :ph34r:
in normal cond.. tarik or not tarik...
change it around 60000km-70000km..
change also oil shield (got 2 for doch), bering, water pump and
3 belt out side. it will cost u around RM400<
not include labour.. :D
Write your reply...
