Hi there, I'm selling my project car away. Basically I've completed the engine and chassis parts, all you need to do is paint the car and replace something that you dont like.
Power: 270WHP (1.0 bar), 300WHP(1.3 bar) (Dyno-ed)
Manufacturer: Proton
Model: Wira C99 (1.8 Double-Stitched chassis by Proton)
Year: 1997
Color: 555 Blue Mica (Painting needed)
Endorsement: Endorsed 1.8 (JPJ Approved)
Accident Free
Engine: (Condition 9.5/10)
Mitsubishi 4G63 Complete Evo III
Genuine Tial Wastegate Made in USA
Genuine Mitsubishi Blow Off Valve
Genuine Mitsubishi Metal Gasket
Genuine TD05-20G Turbine (Daily 1.0 bar)
Genuine Mitsubishi 2364 stock ECU
Tomei Fuel Regulator with Gauge
Genuine Mitsubishi Evo III Intercooler
Genuine Mitsubishi Evo III Oil Cooler
Hurricane Open Port Air Filter w/ 609 air flow sensor
Complete Steel Piping for Intercooler
Exhaust: (Condition 9/10)
Genuine Turbo S Banana Manifold
Genuine RSR Magic 3.2 inch Muffler
Aftermarket Stainless Steel 12inch Resonator
Ignition & Fuel:(Condition 9.5/10)
Genuine NGK Iridium 7 Plug
Genuine Ultra Blue Point Plug Cable
Genuine Walbro 255LPH Fuel Pump
Genuine Mitsubishi 4WD Fuel Tank
Genuine re-conditioned alternator (Replaced on Jan 2016)
Drivetrain: (Condition 9.5/10)
Genuine Mitsubishi Evo III Gearbox Locked 2WD
Genuine Mitsubishi Evo III Exedy Clutch (Clutch pad 95%)
Genuine Mitsubishi Semi LSD
Genuine Mitsubishi Driveshaft (Very good condition)
Braking: (Condition 9.5/10)
Genuine Mitsubishi Twinpot brake kit from Evo III
Genuine Mitsubishi Evo 3 dual layer brake pump
Drilled Rear Rotor
All wheels are PCD100
Handling: (Condition 9/10)
K-II 4 spokes 16x7JJ ET38
2 front new tires (99%)
2 rear tires (70%)
Improve Hi Lo Adjustable Coilover
Improve 6k220 spring rear 4k300
Genuine Ultra Racing Fender Bar
Genuine Mitsubishi Evo 3 Front Anti-Roll Bar
Genuine Mitsubishi FTO Rear Anti Roll Bar
Genuine Mitsubishi Evo 3 Lower Arm Bar
Genuine Mitsubishi Evo 3 Front Frame
ALL bushing just changed new, chassis has no weird sound at all
Interior: (Condition: 9.5/10)
Genuine Mitsubishi FTO original seat (Seats setting are functioning, no torn at all)
Genuine Elevo 13 inch Deep Dish steering
Genuine Mitsubishi Evo III Dashboard with full working digital air cond panel
Genuine Proton Wira C99 Doortrim with all power windows functioning
Genuine Proton Wira C99 Rear seat
Genuine C's Short Shifter
Genuine Razo Type 230 Gear Knob
Genuine Proton C99 Gear Lock
Exterior: (Everything is good except the color need to repaint, rated 6.5/10)
Genuine Mitsubishi Evo 3 Brown Cromax all around (rear wiper is functioning)
Genuine Mitsubishi Evo 3 Green Cromax Windscreen
Genuine Mitsubishi Lancer GSR Side Skirt
Genuine Mitsubishi Auto Flip Side Mirror with switch (need to service)
Replica Proton Wira C99 Spoiler
Tuning:
270WHP dyno-ed via Dynojet in GT Auto Sunway (1.0bar only, 300WHP in 1.3bar)
Dyno chart will be provided with date and figure to prove.
Accessories: (Condition 9.8/10)
Genuine HKS Mechanical Boost Meter
Replica Apexi Turbo Timer
Genuine Mitsubishi Evo 3 meter cluster (brand new from New Zealand)
Standard OEM car alarm system
NEW TIMING BELT
NEW BATTERY (Yuasa DIN66, relocated)
NEW OIL SEAL
NEW ENGINE OIL (VOLTRONIC)
NEW TOYOTA LSD GEAROIL
NEW CASTROL BRAKE FLUID
Remark: (IMPORTANT)
THE CAR NEEDS REPAINT
Price:
RM14500
Contact: (Direct Owner)
016-4098398 Mr. Ong
Car can be viewed in Penang Island from 7-March-2016 Onwards
Year: 1997
Accident Free
Drilled Rear Rotor
2 rear tires (70%)
Tuning:
NEW TIMING BELT
NEW OIL SEAL
Remark: (IMPORTANT)
Price:
RM14500
016-4098398 Mr. Ong
