Anything worth its salt on the asphalt puts its power to the ground through a dual-clutch gearbox. It’s currently the Holy Grail of gearboxes, slashing shift times...
Currently using this type of model (MTX-8) , just want know what the difference between RPM LIMIT and RPM CUT that got on the handset. Other thing is the boost limit at 25 PSI so if i just off the boost cut , will...
hi all,
my car got some problem
1)the check engine is on and never turn off.why?is it indicating problems in the engine?
2)petrol problem.when full throttle/max boost,can smell petrol from outside and even inside the...
