Pathway-To-Glory: 1UZ-FTE KE70!
EFN
Batu Caves
Since I would NOT be able to afford another project car...lets talk about some dream setup that I have in mind ya.
Objective: Hardcore RWD Powermonger!
Car Platform: Toyota Corolla GL KE70
Engine Base: 1UZ-FE V8
Chassis Prep:
- Strip down everything from chassis - Rust repair & replacement
- DIY Removal of crud, tar & coatings
- DIY MIG Spot Weld on seams all round
- DIY 10 Point Roll Cage (No Halo Beam)
- DIY Hammerite Paint for Inner/Undercoat
- DIY Paintwork
- DIY Lightening on hoods, bones & anything that can be thrown away
Driveline Prep:
- AE86 T50 GB
- AE86 Propeller Shaft
- AE86 Rear Axle
- AE86 Manual Steering Rack
- KAAZ 1.5 Way 80% Lockup Limited Slip Differential
- T50 GB Rebuild & Servicing
- T50 to 1UZ-FE Bellhousing Adapter
- Re-balanced Flywheel
- Triple Plate Clutches
- Front 15X8 Offset 0 Wheels
- Rear 15X10 Offset 0 Wheels
- Front 205/55/15 Semi Slick Rubbers
- Rear 245/55/15 Slick or Semi Slick Rubbers
* If T50 + AE86 Axles not enuff, customize a Hilux Rear end as replacement
Suspension Prep:
- Front Ground Control Short Stroke Conversion
- Tokico HTS SS Catridges Front & Rear
- TRD 8/6Kg SS Springs
- Big Ass Sway Bars
- Custom Panhard Rod
- Cusco Camber Plates
- SuperPro PU Bushes all round
- 1UZ-FE Engine Mounts mod
Brake Prep:
- AISIN Nissan 4 Pot conversion incl Disc
- AE86 Rear Disc Brake set
- Steel Braided hose all round
Engine Prep:
- 1UZ-FE Motor + Complete Harness
- Complete Head Rebuild, Gas-Flowed Ports & Refinement
- New gaskets & seals all round
- Valve Seat Cuts
- 288/9mm Quad Cams regrind (Australian custom works)
- ARP Bolts Upper & Bottom
- Crankshaft refinement & rebalancing
- Pistons & Rods refinement
- Aircond & Power Steering Removed
- 2 unit of 4A-GE Silvertop 41mm Four Throttle Assembly
- 2 unit of Four Throttle Adapters
- TPS Mod and adaptation
- Custom Aluminium Intake Plenum with Built-In Velocity Stacks
- 10mm Fuel Line conversion & rerouting
- Singular Controlled Adjustable Fuel Pressure Regulator
- 300LPH Twin Fuel Pumps + Surge Tank
Turbo Prep:
- Single Garrett GT42 Turbine
- Turbo Rebuild & Servicing
- Thermal Wrapped Pipes All Round
- Custom Turbo Manifold
- Custom Downpipe
- TIAL External Wastegate
- Twin BOVs
- Apexi N1 Bomber 4" Exhaust System for Turbos
Engine Management Prep:
- Motec + Aux Injectors Controller + Boost Control Unit
- 1000CC Aftermarket Injectors
- 3Bar Map Sensor
- Aux 4 unit 300CC Injectors Plumbing - Manifold Pressure triggered after 1BAR
- Magneti Marelli Ignition Systems
- Boost 28PSI
- Countless Hours of Tuning hahahahaha
Interior Prep:
- AE86 Dashboard, gutted & lightened
- 1UZ-FE Meter Console + Harness
- Custom Long Lever Quickshift
- Custom Steering Spacer
- Race Spec 13.5" X 30mm Steering Wheel
- Race Spec full non reclining bucket seat (1 Unit only)
- Race Spec 4 Point 3" Harness
- Dash Mounted Kipas Angin hahahaha
Horsepower Target: 700HP at the Rear Wheel
Weight Target:
Under 800Kg
Quartermile Target: UNDER 9 secs
0-100 Target: Under 2 secs
Project Duration: 2 years (Estimated)
Project cost: RM80,000 (Estimated)
So anybody wanna sponsor me? HAHAHAHAHAHAHAHAHAHAHAHAHA!!!!
perghhh,..your dream ha make me crazy Oo,...cannot imagine la if that dream come true...ehehhehee,.
EFN said:
- AE86 T50 GB+AE86 Rear Axle
sure must use other tahn ae86 maa...700hp la...
700hp still want to use 15? go 18 la....still got alot of torque form the v8
front maybe ok...but rear stock ae86 no la...700hp ma!!!
Hahahaha gila kuasa!
T50 won't be able to withstand the torque from the V8. Get the 5 speed W58 (or is it W55) or 6-speed V161 from Supra, Dellow got the bellhousing to match it to the V8. Rear axle need to use Hilux's.
Turbo, use 2 GT25Rs. Less headache for the piping. There was a Celica RA28 running 1UZ-FE with 2 TD06s at over 600hp.
Did someone mention MR2 V8?
http://arrakis.mk84.com/repo/v8incar.jpg
Muahahahahahhahahaa :D
BAGERO MK!!! as me and Netmatrix suspected HAAAA!!! the truth is out now hahahahaha....my thread was just intended to fish u out hahahahahhahaha......
Alo fren when project siap ha? me wanna drool over laa hahahahahah
efn,
ya, like mk mention, t50 will kaotim very fast even on ori 1uz... (somore urs hardcode monster mod)..... at least a w-series or r-series gb lah but if got v161 lagi chun( but here where to find and damn expensive) saw few ae86 with 1uz inside..... damn cool wei......
can i ask questions erm if use gtr 4p0t disc brake should change the lower arm or just plug and play plzzz help :adore:
wah...u looking for 4pot brake and managed to dig up yr '05 post? if u want 4pot from gtr32 and install into KE70..u can look for me. PM me for detail.
