SGP gasket already good enough for standard engine. don't waste money buying metal gasket.its thicker than normal and use for mode head.
SGP gasket already consist of good material and for high compression gti engine.
price: around rm350.
how come? turbo engine use low compression piston. GTI is high compression. the SGP gasket should be much more than enough...
unless you use the wrong piston. please check.
metal gasket for gti come from suzukisport only But at Aus, they do make for gti.its a copper thick head gasket.the price is close to rm1000, 1 pcs head gasket only.
