Over Size Disc Rotor Various Car Model
kent20
http://redlinemax.blogspot.com/
285MM Over Size Disc rotor
Available now For:
Jazz/City/Vios/Yaris 303mm/Myvi
front Disc
Compare with Original Size Rotor
The 285mm Disc
Only Suitable for 15" Above
Able to Use Original Caliper
Increase At least 40% of original Brake Performance
Pls Call 012-2023765 (kent)
Rm850(disc only,cliper use original)
4port set
Rm2950
including
brake pad/4port caliper/Rotor Disc/Steel brake hose
this is for 4port caliper set
u got 4 pots caliper set for hyundai elantra x20?
pm me if u have....
hi may i know if you have a 303mm rotor?
need to know this info as well
center hub =
pcd and hole =
thickness =
offset (rotor height) =
thanks...
