Original Fitting Sound System for Toyota Camry Yr.07 and Onwards
ICE -In Car Entertainment
autocrazee
This is the speaker set, and it comes in four pieces- two pieces for the front door and two more for the back seat. No screwing around literally, just unplug your existing stock speakers and plug these monsters in, turn up the volume and you’ll be wrecking havoc in the neighborhood.
All connectors has been designed with ‘compatibility’ in mind, which means you literally just need to plug-and-play these speakers into your existing wirings.
The anti-vibration sponges keeps vibration at an all-time low.
Here’s the 25mm tweeter, which comes in a pair, giving you all the high pitches you want from your tracks.
These are the only 3 connecting cables you will need to power the whole system- the Power Cable (with the fuse)…
…the amplifier to head unit cable…
…and the ground cable.
And how can this Camry ‘full suite’ be complete without sound proofing elements? These specifically Camry-tailored sound proofing materials are ready to be applied right out of the box, covering any ‘loopholes’ in your Camry that could interrupt the maestro in the orchestra. Tips: These are very sticky, so handle with extra care.
The family potrait, minus the sound proofing members (just not enough space to get everyone on stage!).
Toyota Camry Audio Replacement System
Hi this should also fit directly to Tyt Mark X 2008 (GRX120), right?
Hi,
I'm not too sure about that. If the MarkX is same as the Camry, then highly likely it will fit, but I can't be surre on this.
Regards,
David
Cuz I've seen the original speakers of my car and it looks to have very similar casings and connectors like what you offer now and it's also a 6x9 (but with pitiful magnet size!). The top corner of the dashboard also has place for tweeters. Where is your shop location? If you have GPS coordinate that would be very helpful too.
