offset question..
sr384
hello mates!!
im using r34 gtt..i have a question regarding offset for my car..
can sum1 explain me regarding dis..
is my gtt offset same as gtr r34 offset?good day all!
offset is not on the car. Its actually the physical characteristic of your wheels or rims.
positive offset, negative offset, zero offset is all the wheels characteristic all together with its diameter, width and also the PCD.
here, check this link:
http://www.rimsntires.com/rt_specs.jsp
ET is another word for offset.
generally gtt uses from +40mm uptill +30mm offset rims while gtr +30mm to +12mm offset wheels, to have lower or even negative offset you need to widen your fenders. offset by itself means how far off your the wheel hub are against the center of the wheel.
New Posts
