Need Help On a Skyline!
guy's dont trust your mechanical speedo too much.... nanti disappointed.
i have a digital speed readout i installed on my car and although on my meter cluster it looks like im already doing 240.... when i check my more accurate digital meter it only says something like 220... what a kill joy hahaha!
iziit true? coz my friend though it something wrong with the nismo meter..:hmmmm:
any mechanical speedometer is not as accurate as a digital speedometer at higher speeds
check em both out, at speeds up to about 100-120 the mechanical one should be about right, but anything above that it usually over-reads (esp the nismo cluster)
You will also need to take the size of the wheels into consideration, as the meter are designed for original factory wheels speed rotation reading...So, if you have bigger size wheels like 19" or 20", the reading is not accurate anymore, just like what Farizio mentioned just now...you need to add extra meter for it...:smokin::smokin::smokin:
alright.,, its actually his car just change to 19'', n the nismo cluster reading lack off 20km/h behind compare the digital meter tat he extra installed.. :)
