Myvi SE problem Pls Help
hye guys, why my myvi temperature suddenly rise, the battery indicator light up and the steering is heavy like there is no power steering at all?:bawling:
for high temp..
check your fan radiator...
you can check by on your aircond & feel it... cool or hot..
if hot that mean your radiator fan motor have a problem..
coz myvi aircond & radiator share 1 fan..
i already experience this problem..
change radiator fan motor from toyota camry hehehe..
coz camry motor made in japan :biggrin:
and myvi std fan motor made in INDONESIA hahaha
*sorry for my broken english...
for steering feeling heavy during turn, most likely is because the battery is weak or the alternator is not functioning well. For my wira last time it was due to the alternator. Everytime I make a full U-turn, I noticed my voltmeter shows a significant drop in voltage. After I changed my alternator, no more issues.
errr....is myvi using electric powered steering??
i tot it was hydraulic???? :hmmmm:
care to explain what is the relation between voltage and power steering fucntion on myvi??
I not sure about myvi bro, it was my experience in my Wira last time when I notice a drop in voltage when I make a U-turn with the battery indicator light up . Anyhow, later I have to change my alternator due to the car couldn't get started.
temperature rise: check back your radiator fan
battery indicator: check your battery..you have stated that your car 2 years already..most of myvi battery 'kong' after 2 years..
steering heavy: check your steering fluid
Write your reply...
