MTX Thunder 6000 T6.5 component set..Cheap..cheap!!
ICE -In Car Entertainment
arkeen
MTX Thunder 6000 T6.5 component set for sale
Condition: used.
Reason for selling: Upgrade :tongue:
Price: RM350
Picture upload from MTX website..later i upload the original one coz just taken out from my GTI but its exactly same .
PM me for more details... :biggrin:
Key Features:
titanium-plated injection-molded polypropylene cone
3/4" PEF dome tweeter
2-way crossover (4,700 Hz)
frequency response 65-20,000 Hz
power range 2-40 watts RMS
peak power handling 80 watts
sensitivity 83 dB
depth 2-1/4"
The front stage in car audio means that if you shut your eyes, you can visualize the location of the performers and instruments on "stage" during a live performance. It's the front speakers that recreate an accurate front stage experience. Thunder6000 Convertibles are one of the most flexible ways that you'll find to add superior musicality and accurate staging to your car audio system.
We call these convertibles, but they ain't no ragtops. They ship to you as a coaxial with the tweeter mounted inside the midbass cone. In two easy steps, you can remove the tweeter and convert to separate components.
The tweeter on the convertibles is a sonically pure, 19 mm PEF dome, with a ferrofluid cooled neodymium magnet. In any configuration, the tweeter swivels, and when it converts to a separate tweeter, you can mount it using the included flush or surface mount accessories.
The midbass speakers have been highly engineered for superior sound quality. The cone material is an injection-molded polypropylene with pure titanium deposited on the surface. Aside from the striking appearance, this type of cone construction contributes to the speaker's durability. The machined midbass front and back plates complete the classic look.
CONVERTIBLE COAX to SEPARATE in 2 Steps
Step 1
Remove the tweeter from the midbass driver
Step 2
Insert the phase plug into the opening in the midbass driver and mount the tweeter as a separate, using the surface mount or flush mount option.
Thunder6000 Convertible Specifications
Model T6.5
Description Convertible
Imped. 4 Ohm
Tweeter 19mm
Midbass 5 1/4"
Frequency Response 65Hz-20kHz
Power Handling
(RMS/Total) 40/80
Sensitivity 83dB
Voice Coil 1"
Mounting Depth 2.0" 2.21" 2.71" N/A
:rock:
hi
can this support rock ford woofer 12 inch
if can i take
if can i take
Bro, this is component set.. not amp..and wat do u mean support rock ford woofer 12"?
Ya laa Bro, i also conpius to answer. :rock:
