mods on Accord CF4
aja is busy la lately... new college etc etc...
aftermarket bodykit? what type? in mesia the only places i know that can really custom-make bodykits are daichi and grandpire... actually i only need the euro R or facelifter CF4 front grill and then i will not touch anything else le... cukup...
for racecraft to custom-make CF hood there must be at least 10 firm orders i think
edddial said:
Dzulx,
Mine is now fixed, ok la. Are you going back to Japan?
So what is the reason?? your air filter..
Hmm not is it not good changing ur air filter to mushroom type/??
I want to get the same grille too. Roughly how much is the CF hood?
Daichi and grandpire?? where are they? how much does it cost normally.. hmm really interested:X-:
theres a lot of aftermarket bodykit in japan.. I showed u some previously.. dont remember the link.. But currently, since CF4/CL1 is quiet an old car, not so many bodykit maker still making their product..
dzulx,
I sent to Honda SC & get the throttle body cleaned-up. Then change the RACV. I use HKS air filter but unfortunately it doesn't come with the rubber to fill in the gap, so some air by pass the filter. What I did, I take the rubber (around the filter by the edge) and re-use on my HKS airfilter.
More info click on the link below: RPM Up/Down issue.
BTW, you've got PM.
daichi n grandpire are in sunway. daichi is abit more expensive. for exact cost you must go n discuss with them.
CF hood... i think more than 2k la...
Wow! few more more more more can get H22A la. Get H22A CL1 then no need to change to CF hood la, since already power.
ur car will be faster since CF is lighter than metal... but if u r fat... just get thin la... good enough almost same effect heheh...
All CF-ian kaya2 except me la.. RMT (Rancangan Rakyat Ter-Miskin)
Not all la, I will opt for cheapest solution but hopefully good one. Like amdfaisal said la, another way to make your car light maybe to keep our body slim. Joking only!
CL1 ok la, already power!
CF Bonnet Write Up
Guys just wanna share with U on the improvements I noticed is on the front handling improved and when taking sharp corners the car does not dip and my back does not fish tail easily.
The bonnet weighs 3.5kg compared to the 18kg original bonnet.
It is light as it is made of wet carbon. Cost me Yen100,000.00.
Cost ship from Yokohama to Chiba Yen30,000 and I paid freight to Malaysia
RM900.
Down side of the bonnet is speed exceeding 160kmh U will notice the bonnet flutter and it increases by speed. U will need bonnet clips to hold it down.
If U ask me if it is worth it...well it depends on yr priority and urge to own one.
Avantasia - I am using Custom Tein Super Flex on my car but no clok clok sound. Only squish sound from the damper.
T-R
RM900.
T-R
Brother tuned-r... where can I find spring for tein flex? I found one for back and I need one more for front ... preferable second hand le.. no money :D..
So bro whats ur spring rate?? I found my flex too hard..
My set I bought in SuperAutobacs in Minatomira, Yokohama.
They were selling custom spring fitted Tein Flex with different oil viscosity.
I am running Front 9kg and Rear 7kg.
What is yr current spring rate and what rate U R looking for?
I am planning to change to "Swift" next year if I can get the right for it when I go to Japan on Jan. If my old spring rate is OK with U...I will sell to U then.
T-R
hi tuned-r,
since u will fly to japan on january....can u find upper mount for ek and edfc overthere....is it cheaper than malaysia
T-R
Mine now is 10 & 8kg.. I found 6kg for rear.. bought it only for rm120 back there in tokyo :X-: Rite now wanted to find 8kg for front..
avantasia said:
hi tuned-r,
Malaysia is cheaper if U can get them from Potong Shop or new from N1.
Japan is expensive with the GST. Japan Yahoo Auction used to be reasonable price but now no more with so many Gaijin bidding.
T-R
Wow! Home come so stiff one.
The original set from Tein comes with 6kg Rear and 8 kg front.
What is yr spring diameter 60 or 65mm ?
T-R
