lyzard, i think storm is referring to fine tune the mines to go according to what his engine mod is at the moment, is not necessary to use safc if the mines ecu specs which it was tuned having the same setup with ya car, like cams, fuelling, turbine, fuel pump, injectors and so on, that will be good. other wise in normal case tuned ecu from jap will give u too rich fuelling if it runs under stock setup for ya engine,
btw, hows your pink skyfiro, saw u at pd on sunday, quite bad damage, assuming is your steering broke or something.
