Microtech LT10s for sale
ehdrian
I Don't Care!
Penang
Anybody interested at buying MICROTECH LT10s pls pm me...price is RM2.2k neg..
allo bro from what car , map sensor how many psi , with x4 or not ? condition ?
Just helping out.
Mitsu 4G63T E2
MAP sensor:
20 psi (originally comes with the ecu), without x4 box. Bought from Millenium which doesn't comes with x4 last time.
Condition:
Good and working condition. It is still in the car.
In case you want to know the full spec:
General:
Weight 500gm
Extruded Aluminum case
16 Bit Motorola Processor
Surface Mount technology board
Supports up to 12cyl and 4 rotor engines
Max readable RPM 15950
Standard map sensor 20psi
(28 & 45psi available as an option)
Fuel Delivery:
4 Injector Drivers capable of 4 amp peak hold.
True sequential operation on 4 cylinder and rotary
applications
Run up to 4 high impedance injectors per driver
Tunable in MAP or TPS mode or combination of both.
Main Matrix table has 16x16 load sites
RPM tuning range currently every 500rpm to 9000rpm
Overall Mixture trim +-99%
Fuel Delivery Cont:-
Auxiliary Input correction +-99%
Coolant temp correction
Air temp correction
Accelerator pump amount, sensitivity and Time
compensation
Cranking enrichment correction
After start enrichment correction
Cold Start accelerator pump correction
Hard cut RPM limiter
Soft cut RPM Limiter
Over boost Limiter
Sequential, Group fire and Staged/Group fire modes
Ignition:
4 Ignition drivers
Ignition setup preconfigured for engine type.
Configurable for 1-4 cylinder direct fire or 1-8cyl wasted
spark
Configurable for up to 4 rotor engines
16 Ignition RPM sites
16 Map corrections
16 water temp correction points
16 air temp correction points
Ignition advance/retard on accelerator pump
Ignition advance/retard on aux input trigger
Ignition Trim overall +-45deg
Ignition timing split adjustable on rotary applications
Aux inputs and outputs:-
Standard features include One 12V Aux input
One -ve switched Aux output triggered by RPM, Map, and water
temp
Seperate fan output
Idle Speed control for 2 wire stepper motors
Diagnostics:
Red LED indicated Fault code triggered
Data Page indicates where fault lies
Operational errors:-. Over boost, RPM Limit, RPM Cut, MAX
Duty, Water temp, Voltage, Shift Light
Self Test Mode runs all injectors and ignition and cycles aux
outputs
Amber LED gives Visual of ignition input signal
Green LED gives visual of power on.
Programming/ Tuning:-
Using Laptop adapter and software
Using Handset or DASH unit
Data logging and map storage:
Data Log to Memory (Laptop)
Data log viewable in text or Graph
Playback data log
Print data log
Save data log to disc
4 Maps savable to laptop adapter or handset
Thank you guys who called in for inquiries. The LT10s is currently booked by a friend of Lantistebo from Kuantan.
I will let you guys know if the deal is cancelled.
oi maskulin, u spell my nick wrongly liao la, it's ehdrian...
hai ehdrian and cypress8... well it is my friend who called you yesterday...
Yes bro, i know. Boy is a steady dude to talk with. Hope he got the wiring diagram I sent to him :)
Thanks.
haha, it's ok...i can't think of other nick so i use my name instead..u use B8 engine?..on wat car?..where u from?
ehdrian.....
trade in with e manage ultimate rm?
pm me price...
thank
ehdrian, yap.. i played B8 on Mazda BG 4 doors, I'm from PJ.
-if deal or no deal pls let me know, ok bro.. tq
hey mitgalantvr4, got ppl booked dat mykotek ade..sorry:smokin:
maskulin, sure i'll let u know if it's not sold..hehe :biggrin:
item not yet sold but being booked at the moment, so i'll keep u guys updated if the deal doesn't go on ok..thanx a lot :biggrin:
Bro ehdrian, thanks for the update, will get the gud news from u soon, tq
