Meter with Red Needle & 260km/h
weikee
Put back the local speed meter, swap Speed and Rev needle to red. While doing i clean the meter face place, and also the running number, and adjust the number from 17x,xxx to 7x,xxx (my 1/2 cut mileage), this needle are from W10 turbo (SR20DET). This weekend will go chop shop try search for the small red needle (maybe N15 meter).
BTW, i notice the speed meter from japan and Local are the same everything the same, only thing that make it 180 km/h its because the jumper setting.. the JDM have difference jumper, and the Local have difference jumper setting. If your local one spoiled you can go get the jdm version dismentel it, change the face plate to 260 km/h, set back the jumper (need to solder and desolder) and it should run.
http://www.kodakgallery.com/Slideshow.jsp?mode=fromshare&Uc=1duvzwnb.89aofshz&Uy=aw6ehv&Ux=0
i did not have chance to see the digital version. maybe will get one to do R&D
How to make P R N D 2 1 light on ?
My with JDM meter but the P R N D 2 1 light not working :confused:
Ong: but paulson said that his fren has converted to black face meter v local body harness juz by relocate the wire...... called his fren buit seems to b quite cocky.... so decided not to call again and still finding the rite man to do the job..... any recommendation??
hmm... than i need to go chop shop and find the meter and diy.
if The color coding are the same, just cut and join back all the same color coding, that should do :D
But need to test out first loh.. any one care todo R&D?
of coz i care...!!!!! it took me RM400 for dat blardee meter......!! hehe but very hard oso.... instead actually i got 3 black face meter.... 2 comes with wiring but seems both oso diff. colourr with diff. location...... n oso diff. v our local harness's colour ..... but 1 thing is..... myu fren converted the Daihatsu Storia meter into his kenari...... which 1 is digital n kelisa is analog odometer...... so maybe our ceffy oso can do....
all Taiko/Sifu..Need help..any wiring diagram for black face meter with local body harness..Thanks alot
