LynxSV to 210
Hey guys,
Is any 1 know why after i install the B8 now when i keep running 130-140km/p the water temp is near to 105 ......Why????? can any sifu let me know ???..... Thanks
Originally posted by Lynx210@Dec 30 2004, 11:49
Hey guys,
hi,
is very high.. even i'm boostin all the time my water temp is only max 85 now.
normal driving is only 80... i think you have to check whether got leaking pipe or water pump not strong enough? or put in the water coller.
Originally posted by tkk+Dec 30 2004, 11:54 -->
QUOTE (tkk @ Dec 30 2004, 11:54 )
--QuoteBegin-Lynx210
@Dec 30 2004, 11:49
Hey guys,
hi,
normal driving is only 80... i think you have to check whether got leaking pipe or water pump not strong enough? or put in the water coller. [/b][/quote]
check the temp sensor...
n check your thermostat also...maybe it got something wrong liao... :)
you all using the water temp meter izzit connect to special adapter put in the middle of the hose of engine to radiator 1
put in the middle of the hose hehehehe.
so tonight comfirm 9:30pm meet at rafi ok.
pls contact lynx210 also... so b8 member TT session tonight.
To all,
Okey mean i got to do something.... i dunt put termo coz sifu said no need ok.... im thinking to get a 2,3 layer radiator ...... :unsure:
Sifusssssss......
About my car now is almost dun but only the g/box is still not install coz no money to buy leo hehehe.... :P so only try something with the clucht c wat will going on .... is any1 know 210 ecu (ori) can boost up to how many bar ???? some of my fren said can b 1.4bar with ori ecu but need fuel reg but can use the stock injactor ?????? can any sifu talk bout this ???? Thanks..... :)
