King performance Engine Bearings
synchron
King Performance Engine bearings for sale. More than 90% of engine failure is cause by con-rod bearings. Dont wait until your crankshaft and con-rod to have problem only change them, it might be too late for your engine. Change them to a better ones for preventions.
Current model available for Toyota is as follow:
4ag bluetop
4ag 16v,20v
7afe 7afe 7afe
3sgte(special material)
1jz/2jz(special material)
2e/4e
Bearings can be purchase through me, KSM(puchong) or all other designated dealers.
Dealers are welcome.
Benjamin : 012-2316286
KSM: 012-2229998
Con rod bearing are going for RM 300 and main bearings are RM 350 thrust washer are RM 50. All together RM 700.00, if you buy in a set then got RM 50.00 discount. Price will be at RM 650.00. That is for 4age engines, 16v,20v and bluetop.
3sgte con rod bearings will be at RM 350 and main bearing will be at RM 350 too. Special material is in the 3sgte con rod bearings. And again buy both con-rod and main bearing will be at RM 650.00.
I only got con rod bearing for 4e. It will cost you RM 280.00 because of it size is smaller.
How about installation cost?
Need to rebuild the whole engine only can install this bearing right.
The installation cost will depend on the individual mech.
You dont need to rebuild your car in order to use the bearing. The conrod bearing is to prevent the engine failure.
Every bearings got its life span. Dont expect the bearing to last a life time.
