JL Audio High End components
When you set out to build the very best, you work with only the best. That's why XR component woofers are built with suspensions and cones from the world's best manufacturer of such parts: Dr. Kurt Muller and Co. These parts are expensive, but they also represent the best the world has to offer and are integral to the incredible sonic quality and consistency of the XR products.
The long-throw component woofer features a mineral-filled, polypropylene cone body with a butyl rubber surround and a highly optimized motor system, delivering stunning midbass impact and midrange quality.
The tweeter is a neodymium magnet, ferrofluid-cooled, 1-inch (25mm) aluminum dome with a synthetic rubber surround that damps unwanted ringing for smooth, non-fatiguing output. The component tweeter features JL AUDIO's exclusive RSR mounting system, permitting precise alignment after installation for optimum performance.
High-end, programmable crossover networks with premium polypropylene capacitors, premium inductors and solid-state tweeter protection round out the package. Crossover networks can be programmed to 15 possible settings (3 midrange presence settings, 5 tweeter level settings). The crossover networks are attractively presented in a smoked acrylic case that complements any installation.
This exceptional component system will recalibrate your reference standard for automotive sound.
Description: 2-way System: 6.5-inch (160 mm) Woofer; 1-inch (25 mm) Aluminum Dome Tweeter, Grilles Included
Power Handling: 70W Continuous
Recommended Amp Power: 25 - 150 Watts
Efficiency: 89.5 dB @ 1W/1m
Frequency Response: 48 Hz - 25 KHz ± 3 dB
Frame O.D.: 165.5 mm
Grille Tray O.D: 171.4 mm
Magnet O.D: 82 mm
Frontal Coaxial Tweeter Protrusion: N/A
Frontal Grille Protrusion: 21.2
Xmax: 2.5 mm
Made in GERMANY
Why settle for entry level products when you can get high end products at entry level prices
** ITEM ABOVE IS GENUINE AND COMES WITH 1 YEAR WARRANTY!!
** CALL JOEY AT 012-2070153 TO PURCHASE.
Magnet O.D: 82 mm
Xmax: 2.5 mm
Made in GERMANY
