I just bought a B20B engine half-cut, supposedly built by Feel's.
After re-building the engine and dyno tune, the result came out to be 190 HP at 7K RPM - 20 KG of torque. The dyno graph doesn't seems right. After VTEC engage the power band seems to drop a little.
My power topped at 190 HP @ 7K RPM and the power band drop after that. Along the way, it seems struggling to go up. The entire graph seems sluggish.
Here are my specs:
Head
Type-R with port and polish by Feel's supposedly.
B16B Type-R cams, valve springs & retainer.
Feel's cam pulley.
ARP bolts.
NRG plug cable.
Iriway spark plugs.
Block
B20B with block guard from Feel's supposedly.
CP Pistons 84.5 mm.
Balanced crank.
Standard con rod.
Standard casket (reduce one layer).
Others
Type-R in-take manifold (ported)with Super 90 70 mm throttle body.
F22C injectors.
Standard fuel rail.
Feel's 4-2-1 extractor.
Straight flow centre piping 2.5 inches.
Sard MIG muffler.
Feel's ECU.
E-Manage.
Simota air filter with guppy air ram.
I am planning to change my air filter to K&N.
I am planning to upgrade my cams, valve springs and retainer to either BC or Juns.
Will this two help improve my engine's performance ??
I donno what I am gonna will help or not, still trouble shooting.
Hope to get some valuable comments to improve my ride. Thanks guys.
Here are my specs:
Head
Feel's cam pulley.
ARP bolts.
NRG plug cable.
Iriway spark plugs.
Block
CP Pistons 84.5 mm.
Balanced crank.
Standard con rod.
Others
F22C injectors.
Standard fuel rail.
Sard MIG muffler.
Feel's ECU.
E-Manage.
This topic is to share how to bring out a team and type of engine preparation is needed! N if things goes well it might became true that a team 0-100 member will step up!! I should start with race type...
