Fixed New Thread missing Editor: Hi Everyone, the issue with posting a new thread or a reply that shows a missing editor has been fixed. More updates to the forums will be added on in the coming days, we apologize for the inconveniece this has caused
is it true if our ecu problem or burn, we cannot detect any spark at coil plug. and how to check our injector is ok or not. anyone can give me the answer
basicly if ur ecu burn, open ur ecu & look component inside. ada hitam2 kesan tbakar n u smell it. better send ur car to diagnosis lor.... then u can find the prob. if u want to try.... read that flash code.... n c manual.
how 2 check ur injector? get a small bulb wif complete wiring (got supply n ground terminal @ + n -), then disconnect ur injector wire (got clip) n put d + n - wire (dat connected wif bulb) 2 ur injector, put ur ignition switch 2 ACC position n monitor d bulb, if d bulb blinking then there's nothing wrong wif ur ECU, but if d bulb keep ON or OFF w/out blinking then there's must b something wrong wif ur ECU, d injectors seldom got faulty........ took it from my xperience :-)......
correction, put d wires 2 ur injector supply not d injector :-)
thanx guys. i cannot sent to mechanic becaise my car is at home. and mechanic area my house cannot do the diagnosis. that y i i just wanna check da prob by mannual. if the injector is ok then i just buy the new one ecu. any way thanx again to u all and bro TOMee90 i will try urer way 1st
It's not the most Emmy award winning video we've ever seen, but Russel Han and Ernest Freezo deserve a pat on the back each for their first effort at filming, especially when it's about TIMETOATTACK. Plus, it's a...
