front brake disc upgrade
erm skim = remove material
you can skim material from anywhere?
and the original 2 pot brake disc is 275MM i dont think it will fit without using bracket? so far many ppl skim it smaller? but how small?
anyone here hv been upgrade double layer booster brake servor to ae101 ????i mean seg body...
thanks ... i see the engine bay there not enugh space to put..... anyone done here???
I use Levin knuckle and disc + SS twin port caliper, skim only the bottom part of the twin port caliper, but seems like cannot fit also. The disc is not sitting at the middle of the caliper.
Anyone know what shall I do again besides skim the bottom part of the caliper?
try to skim/reduce/watever the diameter of the disc. make it smaller. but by how many mm/cm, i not sure d.
Using levin disc still need to skim? Then will be skim until the local disc that small ?
looking at it, it seems like you have you add something behind the disc, to push the disc to the front so the disc will sit in the middle of the caliper, but i dont think that is the correct method..
anyone confirm ?
Are you using the SS knuckle that come with it? If you use other knuckle sure need to skim
Nope, i am using Levin knuckle.
btw, I am sure that SS knuckle won't fit into Macpherson.
