Electronic Gauge for A32
Cheongxp
Selangor
Hi,
Recently read the magazine introduce at Throttle Controller & AT Controller.
For Throttle controller only applicable for Electronic Throttle, A32 is Wire Cable Contol ?
http://www.d1spec.com.tw/style/frame/templates8a/product_detail.asp?content_set=color_1&lang=2&customer_id=2349&name_id=101741&rid=56214&id=315720
For AT controller, some said can be use Eletronic Throttle or Wire Cable Control, but some said not.
which is correct ?
http://www.shadowmotor.com.tw/at-controller.htm
http://www.zerotohundred.com/newfor...itenaz-racing-shadow-at-shift-controller.html
Anybody experience for A32 ?
Sorry for the newbiew question !!
Need advice from you guy !!!
A32 is cable throttle so E Throttle controller no use. With regards to the AT controller have to ask if it can be installed for the A32 as all cars has their own AT ECU and have to see if the AT controller can fit.
Finally somebody responce to this thread.
I also thinking so.
My 2.5L run by single ECU instead of local spec with 2 ECU.
I believed seller also can't answer for our Cefiro question, rare people play with this fatty now.
I email the seller already in the thread see if they respond or not.
I find the engineer who program the A32 3.0L AT ecu is a real dung goi. Make the down shift from 3rd to 2nd so stubborn. Don't want to down shift until tekan alot only down shift. Wasting fuel also. Really irritating when going over humps and slow corners. Always have to downshift manually to 2nd.
The seller replied on the other thread and said the device cannot use for the A32. Damn.
