does any1 using C's quick shifter for BNR34 6MT? understand that C's has discontinued this product.
Not recommended. The problem with short shifters is you don't give the synchros in your getrag transmission enough time to work.
You end up with a notchy, and noisy box fairly quickly as your synchros will let go.
thx pimpin, do u remember when u bought the c's short shift, does it comes with the bush (white) at the bottom? i need that actually...[PIMPIN];3349640 said:Correct.
After 6 months, the wear and tear on the synchros was obvious. Plus, in the mornings the crunching while cold is much more apparent.
Was a bad choice.
