Cooz Auto Garage
Cooz Auto Garage
brother
cheras,kl
ALUMINIUM RADIATOR
ARC Aluminium Radiator for Honda EK EG VTEC
VTTR
BRAKE PAD
BLUE SPORT
VTTR Blue Sport Brake Pad For Honda Civic FD
VTTR Blue Sport Brake Pad For Lancer GT Inspira
HARDRACE
HONDA
Civic EF/CRX Front Camber kit 6809
Hardrace Front Upper Camber Kit Honda EK
HONDA CIVIC EK HARDRACE PEAR LOWER CONTROL 7112-G ARM
ACURA INTEGRA 90-93 TRAILING ARM BUSHING REAR HARDRACE 6385
HONDA CIVIC EK EG HARDRDACE 6110 REAR TOE CONTROL ARM
HONDA CIVIC EG HARDRACE 6329. FRONT UPPER ADJUSTABLE CONTROL ARM
HONDA CIVIC EK EG DC2 HARDRACE 6112 REAR UPPER CAMBER KIT
HONDA CIVIC EK HARDRACE 6204 FRONT UPPER CAMBER KIT
HONDA CIVIC ES.EP3.RSX.DC5 HARDRACE 6342 REAR CAMBER KIT
STREAM RN 6396 HARDRACE REAR CAMBER KIT
AROSPEED
Arospeed Light Weight Crank Pulley For Honda Civic EG 96 EK 99
Arospeed Light Weight Crank Pulley For Proton Satria GTI 4G93
Arospeed Light Weight Crank Pulley For Mitsubishi EVO123 4G63
Arospeed Light Weight Crank Pulley For Produa Kelisa Kenari
Arospeed Light Weight Crank Pulley For Perodua Myvi 1.5 Avanza
Arospeed Light Weight Crank Pulley For Perodua Myvi 1.3
Arospeed Light Weight Crank Pulley For Proton Campro
Arospeed Light Weight Crank Pulley For Proton Waja 99-04
Arospeed Light Weight Crank Pulley For Toyota Vios 07-11
SIMOTA
AERO KIT
SIMOTA NISSAN LATIO LIVINA
SIMOTA AERO KIT Filter For Honda CR-Z
SIMOTA DC5 OPER POD AERO KIT FILTER
SYNERGY RADIATOR
SYNERGY RADIATOR FOR MITSUBISHI EVO123 Wira 4G93
SYNERGY RADIATOR FOR MINI COOPER MR BEEN
AROSPEED PLUG CABLE
AROSPEED PLUG CABLE FOR TOYOTA STARLET EP82
AROSPEED PLUG CABLE FOR TOYOTA AE86 LEVIN
AROSPEED PLUG CABLE FOR TOYOTA STARLET EP71
AROSPEED PLUG CABLE FOR TOYOTA LEVIN AE101 AE111
AROSPEED PLUG CABLE FOR EVO 123 4G63
AROSPEED PLUG CABLE FOR PROTON 4G93 DOHC GSR Turbo
http://www.zerotohundred.com/newforums/engine-and-performance/445919-wts-arospeed-plug-cable-for-proton-4g92-sohc.html#post1064495067
http://www.zerotohundred.com/newforums/engine-and-performance/445920-wts-arospeed-plug-cable-for-mitsubishi-mivec-4g92-dohc.html#post1064495068C
http://www.zerotohundred.com/newforums/engine-and-performance/445921-wts-arospeed-plug-cable-for-honda-h22a.html#post1064495069
AROSPEED PLUG CABLE FOR PROTN GEN2 SATRIA NEO
http://www.zerotohundred.com/newforums/engine-and-performance/445924-wts-arospeed-plug-cable-for-mini-cooper-mr-been.html#post1064495072
Engine and performance
  • Piper Racing Cam Shaft
  • Banana Turbo Manifold
  • Power Timing Belt
  • Power Timing belt
  • http://www.zerotohundred.com/newforums/engine-and-performance/286704-coozauto-magpower-ii-oil-filter.html
  • Arospeed Lighten Crank Pulley
Blow Off Valve(BOV)
  • SARD R2D2
  • http://www.zerotohundred.com/newforums/engine-and-performance/221383-wts-blitz-b-o-v.
Cooling System
  • ZAP Oil Cooler Kit
Air Filter/Intake
  • caldina GT4 Air Ram Pipe(Turbo)
  • Honda Mugen Design Air ram
  • K&N open pod air filter
  • http://www.zerotohundred.com/newforums/engine-and-performance/259082-wts-toyota-caldina-air-ram-pipe.html
Transmission system
Fuel Line system
  • Genuine SARD Regulator
  • SARD Fuel Pump 2.8L
Silicon hose
Electronic & Gauge
  • Greddy V-emanage
  • Greddy E-Manage
Accessories
  • Stearing Quick Release NRG
http://www.zerotohundred.com/newforums/exterior-and-body/296313-sparco-style-bonnet-spring-hook.html
  • http://www.zerotohundred.com/newforums/interior-and-cockpit/200615-wts-wira-saga-gear-short-shift.html
Engine Oil
  • Arospeed Oil Sum Nut
Used Part
  • Mitsubishi evo side miror flip for wira
---------- Post added at 03:01 AM ---------- 6 hour anti-bump limit - Previous post was at 02:56 AM ----------
  • Power Timing Belt
  • Power Timing belt
Blow Off Valve(BOV)
  • SARD R2D2
Cooling System
Air Filter/Intake
Transmission system
Fuel Line system
Silicon hose
Electronic & Gauge
  • Greddy V-emanage
  • Greddy E-Manage
Accessories
Engine Oil
Used Part
---------- Post added at 03:22 AM ---------- 6 hour anti-bump limit - Previous post was at 03:01 AM ----------
  • Power Timing Belt
  • Power Timing belt
Blow Off Valve(BOV)
  • SARD R2D2
Cooling System
Air Filter/Intake
Transmission system
Fuel Line system
Silicon hose
Electronic & Gauge
  • Greddy V-emanage
[/URL]
  • Greddy E-Manage
Accessories
Engine Oil
Used Part
