E ek_elleh 500 RPM Senior Member Joined Sep 5, 2005 Messages 575 Points 1,518 Location KB Apr 25, 2009 #1 hi.. i have found a cefiro halfcut with rb25neo(4wd-auto)... can the engine and front driveshaft be fitted to ecr33 (FR-manual).. my car has been off road for almost 1.5 years.. thanks
kaminari 1,000 RPM Senior Member Joined Nov 14, 2003 Messages 1,031 Points 3,148 Location Taiping Apr 25, 2009 #2 Can but turbo spec will nt be the same. Minor mod: Take out 4wd neo oil pan and auto-trans and use back ori ECR33 oil pan and gearbox.
E ek_elleh 500 RPM Senior Member Joined Sep 5, 2005 Messages 575 Points 1,518 Location KB Apr 26, 2009 #3 kaminari said: Can but turbo spec will nt be the same. Minor mod: Take out 4wd neo oil pan and auto-trans and use back ori ECR33 oil pan and gearbox. Click to expand... if want to use manual gbox, can't use 4wd system??? ps:tom, dah tukar nombor ka.. call x dpt..
C cmng 3,000 RPM Senior Member Joined Nov 17, 2003 Messages 3,289 Points 3,148 Apr 26, 2009 #4 that bugger at japan la cannot use 4wd la if can use 4wd.. many GTS or A31 is running 4wd already la you want still can.. cut your engine chassis side . that why GTR and GTS4 is still exclusive in the market
E ek_elleh 500 RPM Senior Member Joined Sep 5, 2005 Messages 575 Points 1,518 Location KB Apr 26, 2009 #5 also found r32 halfcut gts-4 with rb26dett in it.. is it worth to buy at Rm10k?? gbox manual 5 speed..
