BMW E90/E91/E92 H&R Performance Springs
dre42
7,000 RPM
Bmw e36 h&R springs
BMW E39 (520i,520d,523i,525i,528i,525td,525tds,525d,530i,530d)
H&R Springs
Get H & R springs only in our store.
Made In Germany
*Upgrading your suspension components will ensure that your vehicle has improved handling and reduced body roll.
*H&R springs have superb ride comfort and increased driving convenience.
*Will not set or sag.
*Designed and manufactured to be strong, resilient, and more durable than other automotive coil springs.
*Made in Germany
DREGO IMPORTS
No.20m, Jalan PJS 10/2,Bandar Sunway,
46150 Petaling Jaya Selangor, Malaysia
EMAIL : [email protected]
FACEBOOK : https://www.facebook.com/DREGOIMPORTS
MOBILE : +60123505832 ( whatsapp, viber)
OFFICE # 1: 0356110519
OFFICE # 2: 0356361481
GPS: 3.073991,101.61681
H&R Sport Springs
The H&R sport springs provide a slightly more aggressive and raked stance than your stock suspension while still maintaining a comfortable ride. These springs will also fit your stock shocks and are a great and affordable way to lower your BMW. They are also the most popular spring in H&R's line-up, Sport Springs will lower your vehicle an average of 1.5 - 2 inches (depending upon the make and model of your vehicle) for a lower center of gravity and improve handling. Sport springs feature more control than that of the OEM Sport spring, but is still comfortable for daily use. Sport springs are an excellent choice for street and occasional track use.
About Lowering Springs
Aftermarket springs are commonly used to lower the ride height and to reduce body roll. This is also often done when upgrading to a larger wheel and tire package. Generally speaking, the stiffer the spring rates (the amount of resistance a spring is set for against compression), the softer the sway bar setting can be set in order to achieve a similarly flat cornering response.
When trying to decide which lowering springs are right for you, your goal should not be to drop down the car as far as possible. In many cases, overly "slammed" cars may actually be illegal for road use and terrible performers. The ideal range of adjustment should be 0.5 to 2 inches using traditional lowering springs. Any lower, the height of the perch should be adjusted by using a ride-height adjustable coilover suspension.
DREGO IMPORTS
No.20M, Jalan PJS 10/2,Bandar Sunway,
H&R Sport Springs BMW E60 5 Series and M5
H&R Sport Springs
The H&R sport springs provide a slightly more aggressive and raked stance than your stock suspension while still maintaining a comfortable ride. These springs will also fit your stock shocks and are a great and affordable way to lower your BMW. They are also the most popular spring in H&R's line-up, Sport Springs will lower your vehicle an average of 1.5 - 2 inches (depending upon the make and model of your vehicle) for a lower center of gravity and improve handling. Sport springs feature more control than that of the OE Sport spring, but is still comfortable for daily use. Sport springs are an excellent choice for street and occasional track use.
DREGO IMPORTS
Re: H&R Sport Springs BMW E60 5 Series and M5
bring up post...
Re: Bmw e36 h&R springs
bring up post....
new address:
DREGO IMPORTS (001990983-A)
20 JALAN PJS 10/2 (near pro drag)
BANDAR SUNWAY, 46150 PETALING JAYA, SELANGOR
MALAYSIA
Office : +60356361481
Mobile : +60123505832
Email : [email protected]
new address:
MALAYSIA
new address:
MALAYSIA
bring up post
Bring up post
