- Joined
- May 23, 2006
- Messages
- 367
- Points
- 1,516
PROMOTION : RM 60 / BOX
WANNA extend your car's spring & suspension lifespan ?
AMT COIL SPRING BUFFER
Package includes: 1 box: 2 pieces of CSB (Coil Spring Buffer)
Selling Price = 1 box is RM60
-KOREA technology (1 year warranty)
Benefits of using coil spring buffer:-
- Helps restore spring tension and lifespan
- Extend lifespan to sagging coil spring
- Reduces noise and vibration from suspension component (ngek ngek sound)
- Improve stopping capability, Enchances drivability
- Fast Installation and Result Oriented
- Suitable for all types / modal of vehicles (only Ori and OEM Coil Springs)
Installation Guide:-
1) Lift up wheel using car jack
2) Spray soap bubbles over the spring coil
3) Place the coil spring buffer onto the spring coil
4) Lift down the jack...DONE.
Sizes Available:
1. Model A: Spring Clearance (47mm) / Spring Thickness (13mm)/ Spring diameter (173mm)
2. Model B: Spring Clearance (35mm) / Spring Thickness (13mm)/ Spring diameter (160mm)
3. Model C: Spring Clearance (27mm) / Spring Thickness (10mm)/ Spring diameter (131mm)
4. Model D: Spring Clearance (23mm) / Spring Thickness (10mm)/ Spring diameter (113mm)
5. Model E: Spring Clearance (15mm) / Spring Thickness (9mm)/ Spring diameter (112mm)
6. Model F: Spring Clearance (12mm) / Spring Thickness (15mm)/ Spring diameter (120mm)
How to measure your spring?
Available stock for Various Car Models
Forum: Multiplan's Forum - FS / DCarbo (for picture gallery)
Website: Multiplan Enterprise
Email: multiplan.enterprise@gmail.com
Call / SMS: yongfei - 016 - 238 3237
Maybank detail:
MBB Acc: 1010 5809 1666
Poslaju: TBC Later (this stuf is solid and abit heavy, so...)
DEMO:
P/S: AGENT WANTED FOR ALL AROUND MALAYSIA !!!
Bump: bump bump bump
Sizes Available:
Maybank detail:
DEMO:
